My 1927 Model T Coupe Restoration
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
Re: My 1927 Model T Coupe Restoration
Getting the fenders on, if I can get my grandson to work!!! He decided to help so here is the result!!
- First Name: Bruce
- Last Name: Brakke
Just some more pics of progress in the restoration.
- MTFCA Number: 28924
Really nice! Be sure after you install the radiator and coil box to try to start the engine and get any bugs or etc taken care of. It’s a lot easier to get it all tuned up with the fenders off the car and everthing is easy to get to. Keep up the great work.
- First Name: Bruce
- Last Name: Brakke
Sorry about the duplication!!!
- First Name: Bruce
- Last Name: Brakke
Nine coils came with the T when I purchased it in 1954. Eight of the coils tested OK for restoration. I had the "Coil Man" restore five and the other three will be kept for future restoration if needed.
- First Name: Bruce
- Last Name: Brakke
New Day Timer, grandson hooking up timing wires to coil box, and the license plate found at the Iowa State Fair.
- First Name: Bruce
- Last Name: Brakke
Timing wires hooked up, radiator on and hoses attached, and grandson putting oil and anti-freeze in.
...fan belt?
NH Full Flow Float Valves
- MTFCA Number: 24868
On the coilbox, you may want to swing your #1 & #4 sparkplug wire terminals away from the coilbox mounting arms.
This is getting exciting!
- First Name: Bruce
- Last Name: Brakke
Just a photo of the horn that came with the T when I got it in 1954. I have been told it is not a Ford T horn, but I like the sound.
- Last Name: Tannehill
- MTFCA Number: 49460
I would strongly encourage you to put a fuse in the positive line going to the switch.
- First Name: Bruce
- Last Name: Brakke
Seat back upholstery photos. The corner in the last photo is not finished.
- First Name: Bruce
- Last Name: Brakke
Some photos to update the restoration. Carb heat pipe and engine.
It's looking like a car! Looking fabulous, it reminds me of when I restored my 26 Coupe back in 1980-81. Mine needs refreshing after 42 years.
