Was there any part unchanged during manufacturing?
Topic author - Posts: 36
- Last Name: Davis-Williams
- MTFCA Number: 49778
Random question. Was there any part of the Model T which was unchanged in design/material and therefore indistinguishably different through 1909 and 1927?
I assume no.
So, then that leads to my next question. What was the longest period of time that a part was manufactured unchanged and what part was it?
I assume no.
George Davis-Williams
Lake City, MI
1926 Tudor
Lake City, MI
1926 Tudor
- Last Name: van Ekeren
Re: Was there any part unchanged during manufacturing?
A few parts in the dive line come to mind, uni joint, 40 tooth crown wheel and the hyatt bearings. I think the 2 piece valves ran the same for all production.
Define "change"?
Adding the "Ford" script to the water inlet that bolts onto the side of the engine block?
For that matter, define "part"? Nuts and bolts? Even they were changed some over the years.
Records exist in the archives showing changes in castle nuts between rounded cuts or square cuts. However, I am unconvinced that the production lines actually followed those changes very closely.
Frank vE is a pretty sharp fellow! (Totally meant as a compliment!) The two piece valves may come closest to no changes throughout the model T run (although some of the final months of production apparently did get one-piece valves?) The 'crown wheel' (ring gear in American) did have a major change early on. The first year or thereabouts it was riveted onto the carrier!
- MTFCA Number: 14383
40 tooth crown wheel?? Do you mean ring gear? 1919 ford offered a 12:48 gear set for enclosed cars. L cant say they did or did not come from the factory or were dealer installed.
Good stuff guys! I was thinking about the hyatts, but totally stalled out on the valves or ring gear.
In regards to Wayne's question on defining change and parts: To define change I'll give an example. If I were to go to a swap meet and hold two parts what is the longest time-frame between those parts where their difference in age would be indecipherable. Could I hold a 1909 part in my left and the same 1927 part in my right and be totally unable to find a difference?
To define part I would say any object that was specially designed and manufactured for the Model T, but others may have a different definition...which is cool too!
Lake City, MI
1926 Tudor
Lake City, MI
1926 Tudor
John, it depends on what part of the world one lives, at my end, the diff gear set is called crown wheel and pinion.
- MTFCA Number: 51486
One piece valves became available very late in T production, or at least were available for service. (Letter to dealers)
- Last Name: Mills
- MTFCA Number: 29497
- MTFCI Number: 10032
Sort of a trick question without the actual drawing or Record of Change card in front of you. If it was only a chamfer add, or something like that, it stayed on the change card and the drawing did NOT become a 'B'
With that in mind...
My vote goes to T-34 (2529) Steel Differential Thrust Washer 3-3/4" Diameter. Thats the lowest number (I think) that never had a 'B' or higher version.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Perhaps safety wire and cotter pins might be the same over the years.
Thanks Mark! I wasn't around the forum in 2010. I appreciate the link.
Lake City, MI
1926 Tudor
Lake City, MI
1926 Tudor
- First Name: jeff
- Last Name: cordes
- * REQUIRED* Type and Year of Model Ts owned: 25
I've always heard the washer between the axle ends never changed.
- First Name: Trent
- Last Name: Boggess
No, even the cotter pins changed. The earliest ones had legs of equal length. Only later were they made with one leg shorter than the other.
Respectfully submitted,
Trent Boggess
Trent Boggess
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
Ford was making so many more cars thain the prior year as production kept expanding from the early years, that Ford had a hard time finding enought parts suppliers. Even a part that carried the same exact part number and letter suffix made in two different factories, say in 1915 and 1923, representing 8 million cars, could look different . If they functioned the same and didn't hold up production was the main thing.
By the mid 1920's Ford was taking over in house more and more of the production. So if you look to closely at those two parts you may find differences even if they were made the same year or eight years and 8 million copies apart.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
I can think of one part that did not change throughout the Model T production...
And it is still used on almost every car on the road today.
Any guesses?
Any guesses?
- Last Name: Goertzen
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Runabout
- MTFCA Number: 50634
Townsend---
Spark plugs?
Spark plugs?
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Ford sourced the exact same air for the tires from the same supplier
from the earliest T to the last. Look it up !
- First Name: Kenneth
- Last Name: DeLong
Spark plugs changed. Bud.
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Having researched Ford factory drawings at the Benson Ford Research Center, I can tell you from experience that every part drawing that I looked up had changes, sometimes multiple changes in a given calendar year. So were there any parts that didnt change over the course of model T production? I wouldnt think so, but we know that many parts were interchangeable over the course of model T production.
Even air was different from place to place and day to day!
- Last Name: Morsher
Schrader valve cores
- First Name: Keith
Ding, Ding, Ding.
Hold your calls folks.
We have a winner!
We have a winner!
- Last Name: House
- MTFCA Number: 115
Dang ! I just read this thread and was preparing to jump in with Tim’s correct answer. Congrats to you
We’ll share the prize with Keith, George. Talk about a home run of an invention. These were a bicycle age invention, before horseless carriages were much thought of. Likely Henry’s quadracycle had four of them ,too.
- First Name: Jeff
- Last Name: Humble
Schrader valves did change over the years, do not know if they changed during model T production.
- First Name: George John
- Last Name: Drobnock
"Ford sourced the exact same air for the tires from the same supplier
from the earliest T to the last. Look it up !"
However, because of elevation and air density, it required more air to be pumped into the tyres in Denver than in Atlantic City.
- Last Name: Codman
Not sure about T parts, but Ford used the same lug nut from 1932 to 1972.
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
True.Norman Kling wrote: ↑Thu Apr 29, 2021 10:57 amEven air was different from place to place and day to day!
Here in Houston, we don't believe in breathing anything we can't see.
1924 Touring
