Main Bolts changing from Square to Hex?
Posted: Sun May 02, 2021 6:11 am
by Michael_Velling
Hello,
if i want to change the mainbolts from squarehead to hexhead which bolts have i to use?
8.8 / 10.9 ?
Cant find a boltkit at Langs / Snyders or Macs.
Michael
Re: Main Bolts changing from Square to Hex?
Posted: Sun May 02, 2021 8:03 am
by Adam
Modern bolts aren’t usually straight enough to make good main bolts. I haven’t seen any of the new bolts from the vendors for several years, but they sometimes didn’t fit very well either. Try to find some good originals if you can. I would think Langs or someone might have good originals.
Posted: Sun May 02, 2021 11:14 am
by Les Schubert
I have done it numerous times. I do buy Grade 8 fine thread bolts. The fit has always been totally acceptable. I torque them to 60 ft lbs in three stages. For the rear two I grind a suitable flat on the heads.
I first did this in the ‘70’s on a A cranked pressure oiled engine that is still running strong to this day!!
Posted: Sun May 02, 2021 12:20 pm
by Henry K. Lee
I do the same as Les has described! I add stover style locking nuts as well.
Posted: Sun May 02, 2021 1:42 pm
by Dan McEachern
For years and years it was possible to purchase high quality hex head bolts with very straight shanks that worked well for replacement man bearing bolts. Along with new technology came the change to the heat treat process where longer bolts were no longer loaded into baskets and kept vertical when quenched and tempered but rather run thru furnaces on conveyor belts laying flat. After years of spending hours at my fastener distributor sorting cases of bolts to find the ones with reasonably straight shanks and lastly resorting to sorting and then straightening bolts, I gave up and started having main bolts custom made with centerless ground shanks as a last resort. So with that said be very carefull in selecting and using new bolts as its common to find them with up to 1/16" bow or more . For a stock engine, I don't understand why originals are not good enough. They are well-made and plenty out there. Get a 9/16" 8 point socket for the square end and you are all set.
Posted: Sun May 02, 2021 2:18 pm
by Les Schubert
Michael
In Germany I suppose you can only buy Metric size bolts. 12 mm I suspect are marginally close enough fit (but perhaps they do fit nicely (obviously I don’t have any experience with them)). In Canada while we are “officially” metric, Imperial sizes are very available!! So perhaps the best of both worlds!!
Metric “conversion” occurred in the ‘70’s here, but many things have never changed except perhaps in the description!!
So if the 12 mm bolts don’t fit nicely, then perhaps 14 mm bolts and consider getting them ground or perhaps consider reaming the holes. Assuming that a 14 mm reamer is reasonably available.
Just some thoughts!
All the best.
Posted: Mon May 03, 2021 12:14 pm
by Michael_Velling
Hi to all,
thanks a lot. I will have a look at the "Screw-Shop" - after the Lockdown in Germany
The problem is not that i find the original bolts are bad. Here in germany the socket for the square head is not available and it is difficult to do the job.
Stay healthy - thanks for your help
Michael
Posted: Mon May 03, 2021 12:26 pm
by Humblej
Ford wrench 5Z-156 is a tool made for the square head crankshaft bearing bolts. They are plentiful and inexpensive.
Posted: Mon May 03, 2021 1:26 pm
For giggles, i checked ebay. Look for double square 9/16 socket. Many available cheep.
Posted: Mon May 03, 2021 1:40 pm
by Dan Hatch
9/16”. 8 point socket is all you need. 1/2” drive is best. Dan
Posted: Mon May 03, 2021 3:14 pm
by Dan McEachern
Here is a 9/16 8 point socket on E-bay Germany- 7 Euros!
https://www.ebay.de/itm/363378958675?ha ... SwEbxgjCDo
