				Ford Faithful Oil System
				Posted: Sun May 02, 2021 8:33 am
				by jimuris
				Hello does anyone have one of these kits on their car . Not to much information out there on them. Want to know if it's a good investment.
				Re: Ford Faithful Oil System
				Posted: Sun May 02, 2021 9:48 am
				Doing a google search of "mtfca; Ford Faithful" there are lots of entries from post on this forum, these should help;
https://www.google.com/search?client=fi ... d+faithful
				Posted: Mon May 03, 2021 7:32 pm
				by jimuris
				Thank's a lot  that's quite a bit of info.
				Posted: Tue May 04, 2021 6:03 pm
				by Susanne
				I have one, it's a better system (IMO) than the original Ford internal line IF YOU KEEP YOUR LINES TIGHT, mine flows a LOT of oil to the front of the motor...  after running it I can't see a reason NOT to...  it's like free oil for the front of your pan!
				Posted: Tue May 04, 2021 9:43 pm
				I will be putting one on my 25 when I pull the engine. I will not be using the attachment to bottom of the inspection plate, will be plumbing it in to side of pan in about the same area.
				Posted: Tue May 04, 2021 10:45 pm
				I plumb mine through the pan - makes it much easier to remove the lower cover for maintenance !
