Tool identification
Topic author - Posts: 644
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
Tool identification
I picked up a couple and any information would be appreciated!
- First Name: Stephen
- Last Name: Bowers
Re: Tool identification
Looks like a box wrench, and an adjustable wrench.
- First Name: Art
- Last Name: Mirtes
- MTFCA Number: 32489
- MTFCI Number: 24068
What is the dimension of the opening of the open end wrench. Looks like it might be 9/16 or 5/8 in.
Art Mirtes
Art Mirtes
3-Z-675 rear axle wrench
Bicycle Wrench
Bicycle Wrench
NH Full Flow Float Valves
Open end is 1" weighs a few pounds.
- MTFCA Number: 14383
Axle nut is 15/16. that would have been my guess on that tool.
15/16" is most likely spot on. Pics of the assembly line anyone? Would be easy to see. It's a foot long.speedytinc wrote: ↑Sat May 08, 2021 10:59 pmAxle nut is 15/16. that would have been my guess on that tool.
The adjustable wrench is typically English. Just as USA adjustable wrenches are universally referred to as crescent wrenches, these are called King Dick spanners, even though there were many other brands. If that is a faint FORD script on the head, it is most likely for a later English import car. I have a FORD script English made T model adjustable wrench and it is the same type as those used in USA and Canada.
If it is truly 1" then it is for the rear spring perch nut and is probably a 3Z-634, 3Z-629, or 5Z-197. Since it is clearly not a "197" number, I'd suspect it's the 3Z tool. I'm pretty sure that is the only 1" nut on the car.
Michael
I sent you an email
Michael
I sent you an email
- MTFCA Number: 52564
Could be tractor.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 28924
The first wrench looks like it could be agriculture related. Tractors, plows, and various types of other farm related equipment had all kinds of different tools that were general purpose in the Model T -A era. Lots of old tools usually wind up as general purpose since they could be used on different types of equipment areound the farm or workshop.
- First Name: Erik
- Last Name: Johnson
As others have posted, it is a Ford script Z wrench but the three digit number is not very legible due to corrosion.
I have rotated the photo so the Ford script, Z and are upright and easier comprehend.
- Attachments
- Z wrench.jpg (57.92 KiB) Viewed 2562 times
Thanks! Don't know why it posted that way.Erik Johnson wrote: ↑Sun May 09, 2021 10:31 amAs others have posted, it is a Ford script Z wrench but the three digit number is not very legible due to corrosion.
Conjecture on the auction catalog was these were made by students at Henry's tradeschool. Did a bunch of googling. Haven't found anything like it.Allan wrote: ↑Sat May 08, 2021 11:21 pmThe adjustable wrench is typically English. Just as USA adjustable wrenches are universally referred to as crescent wrenches, these are called King Dick spanners, even though there were many other brands. If that is a faint FORD script on the head, it is most likely for a later English import car. I have a FORD script English made T model adjustable wrench and it is the same type as those used in USA and Canada.
To my eyes the Ford script look both right and wrong on the adjustable wrench, maybe just a little off. There was a company called Ford that made tools but was not related to Ford Motor Company or Henry Ford. Am not sure what type face font they used, don't know if it was script or block letters.
1920 Dodge touring
1920 Dodge touring
If that’s a Ford wrench it must have been a factory or dealership shop wrench.
Some better pictures.
Could very well be shop built. A few obvious machining imperfections.
