Just how tuff our T Models are
Posted: Sat May 08, 2021 6:55 pm
by tman1913
It amazes me just how much punishment Henry's Model T can take and still ran.
I have seen a lot of loose rivets over the years when dealing with transmissions. All or some loose but never seen this before.
This had to happen over a period time, but yet kept on running. I slipped the shaft forward just for the picture.
Re: Just how tuff our T Models are
Posted: Sun May 09, 2021 1:07 am
by KWTownsend
Just like Timex watches.
It takes a lickin', and keeps on tickin'.
Posted: Sun May 09, 2021 7:29 am
by D Stroud
Keith, I wonder how many of us remember those commercials?
Dave
Posted: Sun May 09, 2021 7:58 am
by Jerry VanOoteghem
Just after purchasing my '21 Roadster, my dad drove it home, maybe 40 miles. He mentioned that the rear end was a little noisy, so he thought we'd better have a look inside. When we split the housing, the whole differential fell out in pieces. The differential carrier was broken and in pieces and only held together by being squeezed between the thrust washers. Everything inside was total junk. Yet, it worked fairly well. What forgiving little cars these are!
Posted: Sun May 09, 2021 9:11 am
by TWrenn
Not in my case!!
Ironic for this post, cause earlier this week I posted this pic for the same reason. Pic shows the only rivet left...poor thing tried, but just couldn't do it!! Sadly my Fordor was left dead on the road!
Posted: Sun May 09, 2021 10:06 am
by TXGOAT2
What symptoms would loose rivets at that point exhibit that a driver could detect?
Posted: Sun May 09, 2021 11:27 am
by speedytinc
That doesnt happen on its own. Thats the result of serious pan misalignment and/or transmission main shaft not running true. How many guys know to check the drive plate output shaft after assembling their transmission to the motor? Trust but verify.
Posted: Sun May 09, 2021 11:40 am
by Steve Jelf
Recently there was a video on one of the FB Model T pages showing an engine with the head off and the guy rotating the pistons back and forth about an inch. He said it had been running OK that way.
Posted: Sun May 09, 2021 4:51 pm
TXGOAT2 wrote: ↑Sun May 09, 2021 10:06 am
Lots of vibration. A clunk when going from forward to reverse, (or reverse to forward), or starting off after a stop. In extreme cases, if the car is moving: no brakes, if the car is sitting still: won't move.
Posted: Sun May 09, 2021 5:21 pm
by speedytinc
4th main would be leaking a lot of oil from excessive wear also.
Posted: Tue May 11, 2021 5:48 pm
by TXGOAT2
Thanks. Mine must be OK.
Posted: Wed May 12, 2021 9:32 pm
by Allan
They'll even get you home when the universal joint cage splits completely. In my youth I had this happen some 40 miles from home. The two yokes still drove by running against one another. The noise gets quite high, the heat melts the whitemetal out of the fourth main, but the old clunker still got two youths home by midnight.
