First year of the Brass Model T...1908 or 1909...was the brass finish the correct choice?
Posted: Mon May 10, 2021 9:46 am
From the Automobile, 1908. same year the Model T was released on the public as a 1909 model, two articles of interest. The Model T was out and about around January 1908, but Ford was not fully marketing the 1908 Model T - article states it was decided to test it in actual service before putting it on the market.
Article from July 1908 also has comments from "name withheld" AKA Anti-Brass.
Anti-Brass discusses his perfect ideal car. For him the perfect car is rated at 30 hp, three point suspension, 3 speed/reverse transmission, a magneto of atwater-kent design. detachable rims, thermo-syphon cooling. And rather than brass fittings, the trim should be gunmetal or an oxidized finish. For Anti-Brass, time would be better spent to keep the engine transmission in proper shape. For Anti-Brass, the new car owner is his own chauffeur, and time spent polishing brass can be better spent in the maintenance of a vehicle.
That was in July 1908, by September 1908, came the announcement came from the Ford Motor Company, of a new Ford, that produced 20 hp, removable cylinder head for improved maintenance, and a water pump for cooling, transmission with two speeds forward and a reverse. One of the most radical features of the new car was the ignition system., a magneto that was incorporated as part of the flywheel. A three point suspension system with a 100 inch wheel base. And the article for September 1908 stated that there was no announcement about the colours or finish (trim?)
