Magneto Horn Repair
Posted: Tue Mar 12, 2019 11:18 am
by TheSaintDiscJockey
I purchased a magneto horn several months back. I was a able to test it this morning. It was making a noise, then went silent. I kind of figured it would have to be rebuilt when I got it.
Are there any repair folks I can contact? Is there a rebuild kit available? I've done some looking around and have come up blank.
As always, many thanks in advance for any insight.
Re: Magneto Horn Repair
Posted: Tue Mar 12, 2019 11:49 am
by BE_ZERO_BE
As long as there is continuity through the coil the horn should work.
There are no points or other electro-mechanical moving parts - only a coil that causes the diaphragm to vibrate.
The horn will not work if a DC voltage is applied.
Posted: Tue Mar 12, 2019 3:08 pm
The inside of my horn.
A bit confused at this point.
Pretty old and beat up.
Posted: Tue Mar 12, 2019 3:12 pm
Outside, one post.
Posted: Tue Mar 12, 2019 3:19 pm
Assemble it, hook it up to mag power, and try turning the adjusting screw to different positions. As Bob says, if there's continuity through the coil it should work.
Posted: Tue Mar 12, 2019 3:36 pm
by Bruce Compton
Brooks : The diaphragm needs space to move, and that's provided by two paper "gaskets", one on each side of the diaphragm. Make sure that the adjustment screw and locking nut are free before assembling it to make final adjustment easier (possible). Cheers : Bruce
Posted: Tue Mar 12, 2019 11:02 pm
by Jim, Sr.
Magneto horns need to be tested and adjusted with AC power, not DC. An old electric toy train transformer or door bell transformer works good.
I know someone that has a magneto horn hooked up as his door bell.
