Early Bendix Cover
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
MTFCA Number: 51596
Early Bendix Cover
Post by FundyTides » Tue May 11, 2021 5:51 pm
Just sorting through my T parts that I have accumulated over the last 30+ years and came across a Bendix cover that looked a little different. It is an assembled cover. A similar cover is shown on page 278 Of Bruce McCalley's "Model T Ford" with a note that Ford experimented with covers like this in 1919. Do these covers show up on a regular basis or are they quite unusual?
MTFCA Number: 14383
Re: Early Bendix Cover
Post by speedytinc » Tue May 11, 2021 6:16 pm
I have seen a lot of the one year only 19 parts. Including flywheel & ring gear. Have not seen the larger bendix cover, Unless i dismissed it as non T era.
Pep C Strebeck
First Name: Joseph
Last Name: M
MTFCA Number: 0
Post by Pep C Strebeck » Tue May 11, 2021 7:01 pm
I had been looking for one for quite a long while. I found one this last November:
Later pressed style next to it for comparison. Here is a link to my post about it:
viewtopic.php?f=2&t=17288&p=131987&hilit=bendix#p131987
FundyTides
First Name: David
Last Name: Wilson
MTFCA Number: 51596
Post by FundyTides » Wed May 12, 2021 7:38 am
Thanks for the info Joseph. I will post a picture of mine after I clean it up.
FundyTides
First Name: David
Last Name: Wilson
MTFCA Number: 51596
Post by FundyTides » Wed May 12, 2021 4:01 pm
Here's a couple of pictures. I have sandblasted it and it needs a few hole repaired in one side where water obviously collected.
MTFCA Number: 28924
Post by John kuehn » Thu May 13, 2021 8:02 pm
The later version was a better cover probably because it was made from one piece of metal by looking at it. Ford must have had a parts supplier or maybe it was Ford who developed a process where the starter cover could be extruded from one piece of metal. I’m guessing but it would seem that way. I’ll bet it took less time to make and Ford would have liked that.
