1911 touring acetylene generator mount
Posted: Wed May 12, 2021 2:00 pm
by flatbroke3
I am questioning how my generator is mounted to the running board. Mine has a 3/4 inch piece of wood under it to raise it above the ribs in the outside of the running board. perhaps the unit is the wrong size? (base to big in diameter)? I seem to not be able to find any photos close enough to see that area. how do all you seasoned club members have your generator mounted? photos greatly appreciated. or at least a very good description.
Harold Musolf III
Re: 1911 touring acetylene generator mount
Posted: Wed May 12, 2021 2:17 pm
by JTT3
How about some pictures of your generator, that will give the visual to make some suggestions.
Best John
Posted: Wed May 12, 2021 10:51 pm
by flatbroke3
well yes, i should have posted a picture or two. upon looking further I do not think the generator that is on my car is correct. here are some photos[image][/image]
Posted: Mon May 17, 2021 2:55 am
by JTT3
I use a 1/8 inch rubber pad under the base and mount it to the running board. You should have a small round hole in the apron for the red rubber hose to go through from the generator to the light tube at the bottom of the fins inside the engine compartment. From that tube you should have rubber hose going to the headlamps on either side. That generator looks to be a Jno Brown style generator judging from the 3 hole base mount although it could be a Corcoran but most Corcoran’s had 4 holes I believe. I would use flat brass washers and brass bolts on the top side and brass nuts with lock washers on the bottom. Is your generator a reproduction? Do you see a makers stamp on the base of the water tank close to the valve? It’s generally to the left of the valve if it’s an original JB “UNLESS ITS BEEN POLISHED OFF, HA.” The size of your generator is fine. Curious, what type headlamps & sidelights do you have? Is this an original 11? Good luck. Best John
