Not starting...thoughts?
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Board Member Since: 2011
Post by Bill Everett » Sun May 16, 2021 10:03 am
Engine has not been started in a couple of years.
New 12V battery, new fuel tank and sediment bulb, full flowing fuel.
Mixture knob counterclockwise about 7/8 of a turn.
We removed the hot air pipe to make it easier to spray starting fluid.
Carburetor is a Kingston, L-4 I think.
It did start once, and ran for about 4 - 5 seconds, roughly.
Pictures show the settings for the carburetor and the timer.
It did backfire through the carburetor a couple of times, but that got fixed by connecting the spark lever to the steering column!
We're open to suggestions...!
Any help is appreciated.
Thx.
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Re: Not starting...thoughts?
Post by Dave Young » Sun May 16, 2021 10:14 am
Bill. Have you checked the compression? 35 lbs in each hole is sort of a minimum. Getting fire to each hole is the next consideration. Lay the spark plugs, with wires connected, on top of the head, and rotate the crank. See that each plug fires. Next, it’s all about fuel. Skip the ether spray and crank the carb open to two turns. Pour a little fuel into cylinder, put the plugs back in and try to start it.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sun May 16, 2021 10:19 am
Carbe is L4. Try opening the spray needle more. I don't see a gasket between the carb and intake. Have you checked compression? Full fuel flow, have you opened the drain on the carb and let it flow for more then a few seconds? Are you pre priming the motor with the choke? If so, does it sound like you are pulling fuel in, you should be able to hear it.
1920 Dodge touring
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Sun May 16, 2021 10:30 am
Look like the throttle is wide open. Better hope it doesn't fire up like that so hook up the linkage and try again.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun May 16, 2021 10:32 am
You need fuel/air, compression, and spark. It's unlikely that spark would be lost or timing changed just because of sitting. Compression could be lost if a valve or two are stuck open. Fuel is the most likely culprit. Possible problems there include bits of debris in the carb, condensed water in the gas, and a sticking or stuck float valve. Also try starting with adjustment 1¼ turn open. A good starting adjustment varies among carbs.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Sun May 16, 2021 10:56 am
I assume the spark plug wires are connected correctly. Any chance of a problem with the Batt/Mag switch or coilbox connections? Corrosion can sometimes be a problem when a cars has set for years. Pull the coils and clean the contacts.
When it was last shut down was the fuel run out of the carb or has it been sitting for years?
How well was it running when last shut down?
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sun May 16, 2021 10:57 am
Thx.
I agree with Bruce. Why is the carb unhooked ?
I would start here, it’s not gonna start with the throttle wide open.
You show the lever but not the actual timer.
Hook the throttle up, open it about 4-5 notches at the column. Open the mixture about 1-1/2 turns from closed. Make sure the timer is set according with the service manual and try it.
If still no joy, check compression, spark, plugs, coils....
AndreFordT
First Name: Andre
Last Name: Valkenaers
* REQUIRED* Type and Year of Model Ts owned: 1926 ; 1922 ; 1915.
MTFCA Number: 23792
MTFCI Number: 19330
Post by AndreFordT » Sun May 16, 2021 12:23 pm
I should start by draining the float bowl and wait till there is good gas comming out.
Than open the spray needle for 1.5 turns and prime the engine with the trotle lever half way down and the choke closed. Turn the engine over till gas is leaking on the ground.
Set the contact on, set the ignition lever two or three notches down and try to start the engine.
Good luck
Andre
Belgium
MTFCA Number: 51486
Post by TXGOAT2 » Sun May 16, 2021 12:41 pm
Are you cranking with the starter? Is ignition switched to "Bat"? Are you using the choke during cranking? (Hook up throtle linkage!)A T will usually start fairly easily, even if there are some issues.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Sun May 16, 2021 12:56 pm
Compression, timing, spark, gas. Got 'em ? She'll run.
"Get a horse !"
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun May 16, 2021 3:35 pm
It's a brass era car. Most likely there isn't one. Even so, I would start on BAT.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun May 16, 2021 3:56 pm
When working on fuel problems let the gas flow into a white container ... like a white ceramic cup. This will help you see the debris, if any, much easier.
Turn the adjustment on the carb all the way down and then open a turn and a half.
Use a battery and set on BAT
Set the spark on full retard and the gas around six notches.
Crank four times with the choke pulled all the way. You should hear gas sloshing in the carburetor.
Remember to set the spark to full retard! Then turn on the ignition (on BAT) and you should hear a coil buzz. Put the crank at 7:00 and pull up to 12:00 several times and it should start if you heard the gas sloshing and the coil buzzing.
Once started advance the spark and dial back the gas until it sounds good.
TRZim
Last Name: Zimmer
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1914 touring 1915 speedster
MTFCA Number: 15920
Post by TRZim » Sun May 16, 2021 6:48 pm
Make sure your roller on the timer is not 180 degrees off. That will produce the effects you descibed while trying to start car.
It's Bill
First Name: Bill
Last Name: Hoffer
MTFCA Number: 32571
MTFCI Number: 24364
Post by It's Bill » Mon May 17, 2021 2:32 pm
Tried to start my new Joe Bell rebuilt engine, but no go. Finally got back to it today, and found I had switched two harness wires at the coil box. I plead temporary insanity. Fixed the wires, did the normal starting prep as outlined above, and she came to life!
This is not my first rodeo, and I thought I had everything perfect. Goes to show you can't be too careful checking things out.
Good luck, Bill
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Mon May 17, 2021 4:31 pm
Aren’t you glad you found it! Sure beats takings thing all apart to no avail. Good deal!
