Gypsy Curtain Patterns for a 26-27 Roadster
Posted: Sun May 16, 2021 11:57 am
by DontKnowMuch
Does anyone have a pattern for the Gypsy Curtains for a 1926-27 Roadster?
I found some good pictures on this forum but not a pattern with dimensions.
Re: Gypsy Curtain Patterns for a 26-27 Roadster
Posted: Sun May 16, 2021 5:54 pm
by Mark Nunn
...for me too, please.
Posted: Sun May 16, 2021 6:20 pm
by dmdeaton
If you can wait a couple weeks I have a set coming from Car. I would measure and post results unless someone beats me to it
Posted: Mon May 17, 2021 10:21 am
by DontKnowMuch
Thanks for the offer. I will wait to hear from you.
Dennis
Posted: Sat May 22, 2021 5:21 pm
by dmdeaton
Posted: Sat May 22, 2021 5:23 pm
by dmdeaton
Posted: Sat May 22, 2021 5:25 pm
by dmdeaton
Let me know if you need anything else. I don’t know much as I just got them and haven’t even held them up to the car yet.
Posted: Mon May 31, 2021 11:48 am
by DontKnowMuch
Thanks for posting these pictures. I did not see these until this morning. Can you measure one of the angles?? I am very rusty on my geometry.
Dennis
Posted: Mon May 31, 2021 12:15 pm
DontKnowMuch wrote: ↑Mon May 31, 2021 11:48 am
Dennis
If you get the exact measurements of the inner triangle you can use this link to calculate the angles. Since the width of the each frame piece forms parallel lines the outer triangle would have the same angles. All the pictures with the tape measure need to be more accurate.
https://www.calculator.net/triangle-cal ... &x=68&y=23
Here is an example:
Posted: Mon May 31, 2021 3:34 pm
by dmdeaton
Make a template from cardboard first.
Posted: Mon May 31, 2021 8:25 pm
by dmdeaton
I will measure the angles as non are right angles to start with
