mount front license plate
sheppfour
First Name: Chris
Last Name: Sheppard
Post by sheppfour » Tue Mar 12, 2019 11:07 pm
Does anyone have a good picture on how to mount a front license plate on a 1919 model ? Thanks for the help in advance.
CHRIS
MTFCA Number: 16175
MTFCI Number: 14758
Re: mount front license plate
Post by Steve Jelf » Tue Mar 12, 2019 11:50 pm
This one fits the 1921-1927 spring clip. You could make something similar to use the 1920 and earlier spring clip, but it would need to have a jog up or down to miss the crank handle.
sheppfour
First Name: Chris
Last Name: Sheppard
Post by sheppfour » Wed Mar 13, 2019 6:51 am
Thanks, I'll have to make one with some drop to clear the crank
Chris
Jim Sims
First Name: Jim
Last Name: Sims
MTFCI Number: 13377
Post by Jim Sims » Wed Mar 13, 2019 10:28 am
The 19 uses a two piece mount. Part number 3664e in Langs catalogue.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Mar 13, 2019 11:48 am
The above bracket Steve has posted is through 1925 - the '26 - '27 bracket has a "drop" on it.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Mar 13, 2019 12:46 pm
However if your car is Canadian then the front license plate is located below the drivers side headlight. Several different versions depending on the year
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Post by jsaylor » Wed Mar 13, 2019 12:56 pm
Here is the one Lang's sells[.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Mar 13, 2019 1:10 pm
I have the Canadian version on our '19 Centerdoor due to the "anti-kick" device hanging in front !
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Wed Mar 13, 2019 7:56 pm
Have one that mounts to the top radiator neck
But just baing wire at the axle work best
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Thu Mar 14, 2019 12:13 am
The pair of license plate mounting brackets sold by the vendors are worthless.
They need to have dog-legs so the crank clears the license plate.
See the three photos that I posted in this thread - this is what is needed but good luck finding a pair.
http://www.mtfca.com/discus/messages/25 ... 1336307120
