mount front license plate
Posted: Tue Mar 12, 2019 11:07 pm
by sheppfour
Does anyone have a good picture on how to mount a front license plate on a 1919 model ? Thanks for the help in advance.
CHRIS
Re: mount front license plate
Posted: Tue Mar 12, 2019 11:50 pm
by Steve Jelf
This one fits the 1921-1927 spring clip. You could make something similar to use the 1920 and earlier spring clip, but it would need to have a jog up or down to miss the crank handle.
Posted: Wed Mar 13, 2019 6:51 am
by sheppfour
Thanks, I'll have to make one with some drop to clear the crank
Chris
Posted: Wed Mar 13, 2019 10:28 am
by Jim Sims
The 19 uses a two piece mount. Part number 3664e in Langs catalogue.
Posted: Wed Mar 13, 2019 11:48 am
by RajoRacer
The above bracket Steve has posted is through 1925 - the '26 - '27 bracket has a "drop" on it.
Posted: Wed Mar 13, 2019 12:46 pm
by Les Schubert
However if your car is Canadian then the front license plate is located below the drivers side headlight. Several different versions depending on the year
Posted: Wed Mar 13, 2019 12:56 pm
by jsaylor
Here is the one Lang's sells[.
Posted: Wed Mar 13, 2019 1:10 pm
by RajoRacer
I have the Canadian version on our '19 Centerdoor due to the "anti-kick" device hanging in front !
Posted: Wed Mar 13, 2019 7:56 pm
by Nv Bob
Have one that mounts to the top radiator neck
But just baing wire at the axle work best
Posted: Thu Mar 14, 2019 12:13 am
by Erik Johnson
The pair of license plate mounting brackets sold by the vendors are worthless.
They need to have dog-legs so the crank clears the license plate.
See the three photos that I posted in this thread - this is what is needed but good luck finding a pair.
http://www.mtfca.com/discus/messages/25 ... 1336307120
