snyders carb
Posted: Wed May 26, 2021 12:13 pm
by Emeraude
I need a carb for my 1920 engine.( I do not have a carb for a core). Snyders catalog offers a new holly carb for $272.00 without a core which is about the same price as having one rebuilt. Has anyone had any experience with this carb? I should mention this car will only be used in town not on the highway.
Re: snyders carb
Posted: Wed May 26, 2021 12:23 pm
You will be far better served both financially and performance-wise, by purchasing a rebuilt original and paying a core charge if it is required.
You will want to ask the supplier: "Does this rebuild come with a Grose Valve?"
If the answer is "yes" then you want to avoid purchasing that particular rebuild. Grose Valves only work reliably in modern automobiles which have a fuel pump. They are quite problematic with a gravity-feed fuel system.
Re: snyders carb
Posted: Wed May 26, 2021 12:43 pm
helps to check the classifieds time to time; viewtopic.php?f=5&t=21289
Re: snyders carb
Posted: Wed May 26, 2021 2:22 pm
I have seen those being advertised for a while. So does anyone really actually know if the repos are good, so-so or a guess that’s it’s not. And yes I know a good rebuilt original is good also.
Re: snyders carb
Posted: Wed May 26, 2021 2:39 pm
by DHort
Corey usually sells one every week or two. He has an NH in the classified right now. Bruce Compton also sells good carbs.
Re: snyders carb
Posted: Wed May 26, 2021 3:34 pm
I've used a new Snyder's NH - no issues !
Re: snyders carb
Posted: Wed May 26, 2021 3:53 pm
Thanks for the information from a user of the new carb. I must say say that I am not doubting anyone’s Carb rebuilding work. No way.
I guess it boils down if you want to stay original or not. That’s your business if you want to.
If someone can make a good dependable Carb or whatever that’s a good working copy of an original part that’s a good thing.
Re: snyders carb
Posted: Wed May 26, 2021 4:21 pm
Seeing how the new ones are out of stock the whole new vs old rebuilt is immaterial now anyway. But I guess it someone wants to waste extra money on a new one, that for sure is their choice.
Re: snyders carb
Posted: Wed May 26, 2021 4:51 pm
by Dallas Landers
I have a couple of Cory Walkers NH rebuilt carbs. No issues and very happy out of the box.
Re: snyders carb
Posted: Wed May 26, 2021 8:35 pm
by TWrenn
I think Russ Potter has some. Check with him.
