Driveshaft- Pinion Gear puller
Posted: Tue Jun 01, 2021 12:52 pm
by Retro54
Embarking upon a rear axle assembly rebuild and this pinion gear is on here tight enough to give the cheapo harbor freight puller fits. Not wanting to ruin anything and being ready to man up for the right tool for the job, what gear puller would you recommend for this particular application? Thank you in advance for your suggestions.
Andy
Re: Driveshaft- Pinion Gear puller
Posted: Tue Jun 01, 2021 1:44 pm
by TRDxB2
Some threads on the removal of the pinion gear and pinion bearing (the harder of the two)
Gear removal Jelf Method
Take off the nut, turn it around, and put it back on just far enough to be even with the end of the shaft. There should be a little space between the nut and the gear. Then do this: https://www.youtube.com/watch?v=Ta2NCzXcZnA
Bearing http://www.mtfca.com/discus/messages/33 ... 1387761711
Posted: Tue Jun 01, 2021 2:05 pm
by RajoRacer
Loosen the nut a bit and grab a large brass drift and a hand sledge & give the back of the gear a couple good whacks with OR a large brass hammer (2 lb.) works good !
Posted: Tue Jun 01, 2021 2:10 pm
by speedytinc
Neat trick, I will use it when the drift & hammer method is not enough. I have picked up some neat tricks here.
Posted: Thu Jun 03, 2021 6:57 am
by Retro54
TRD, thank you for the information! Dad looked it over and did the 'Jelf' method yesterday. Two strikes and it came right off! I appreciate Steve's common sense approach to things. You do not always need fancy tools, just common sense and mechanical advantage clearly can win the day.
Andy
Posted: Thu Jun 03, 2021 10:44 am
by Adam
In the worst case scenario, A cheap hydraulic press lifted with an engine hoist works great on the stubborn ones.
Posted: Thu Jun 03, 2021 2:14 pm
by Quickm007
I used Jeff Method either and work really well and is cheap. Jeff have a lot tips than I used. Thank you Jeff!
