Stewart Speedo Problem
Posted: Tue Jun 01, 2021 8:15 pm
I live in Melbourne, Australia and have a lovely 1914 Speedster.
I have fitted a Stewart Model 100 speedo and swivel and gears (60 / 16 teeth) on the front wheel. I have serviced both the speedo and the swivel using the MTFCA book Speedometers as a resource. The speed drum rotates freely and smoothly and returns to zero. The odometer registers correctly and shows 1 mile travelled after 1009 revolutions of the input.
Unfortunately, when installed, spinning the road wheel produces no speed on the speedo.
I have found that the swivel ratio is 4:1 when it should be 2.5:1 and I think I can fix this by obtaining the correct swivel from a friend locally.
However the speedo head is the main problem. Under bench test using a drill input, to produce 5mph, the rotation speed of the input must be 225rpm, instead of 84 rpm which I would have expected (based on 1009revs for a mile at 60mph).
I suspect the revolving magnet may be weak.
Have I missed another explanation? Is there a way of testing the magnet? Is there a clever solution to my problem?
Jeff Brown
Jeff Brown
