Firewall insulator on a 27 roadster?
Posted: Sun Jun 27, 2021 10:22 am
by Les Schubert
So I’m restoring a very original “unmolested” 27 roadster. Upon removing the gas tank (which I doubt had ever been removed before), I found a piece of material that I can only describe as being a firewall insulator. This is a late production 27 Canadian roadster that came from north central Saskatchewan. In my almost 50 years in the T hobby I’ve never encountered something like this. No evidence of a heater on this car, although the floor boards are missing. So perhaps it had one that wrapped around the exhaust pipe. Holley Vaporizer carb. Serial numbers match
Re: Firewall insulator on a 27 roadster?
Posted: Sun Jun 27, 2021 10:25 am
by Humblej
Do you mean a small patch of cloth on the inside of the firewall at the gas tank sediment bulb?
Posted: Sun Jun 27, 2021 10:45 am
by RajoRacer
Posted: Sun Jun 27, 2021 10:54 am
by GG Gregory
My very early 27 Roadster had one. I ordered a replacement from Langs
Posted: Sun Jun 27, 2021 10:56 am
by John Codman
My very late '27 touring also had one. I reused it as it was in good shape.
Posted: Sun Jun 27, 2021 11:01 am
by Kevin Pharis
Thanks for that link Steve, I haven’t seen that large cardboard piece before. My ol ‘27 roadster was very original and had a small patch of heavy tar paper (approximately 6” x 8”) riveted to the firewall for this purpose. I assumed that this tar paper was original as there was a perfectly shaped rust out in the front panel of the fuel tank from the tar paper holding water
I guess after 90+ years anything is possible tho...?
Posted: Sun Jun 27, 2021 1:56 pm
by Humblej
OK, know I understand. Yes, my mid year 1926 Canadian coupe had some remains on its firewall when I pulled the tank years ago, not enough that I could make sense out of what it was or what it looked like.
Posted: Sun Jun 27, 2021 2:14 pm
by Les Schubert
Steve
Thank you for the information. That looks quite similar!
Posted: Sun Jun 27, 2021 6:22 pm
by RajoRacer
You all are most welcome ! I believe that's a fairly recent offering from our friends at Lang's !!!
