Bolt check
Posted: Sun Jul 04, 2021 3:42 pm
by Techmaven
Found this when I checked out underneath.
Re: Bolt check
Posted: Sun Jul 04, 2021 3:49 pm
And its wired? Threads must be severely stripped.
Re: Bolt check
Posted: Sun Jul 04, 2021 4:10 pm
I can’t tell if that’s grease or black rtv silicone sealer that’s oozing around the ujoint area. Also the lower left bolt is either stripped or backing out. That’s an area that causes a leak and can be a pain. It could be it needs a shim that’s available to put between the ball joint area that tightens it up a bit.
Re: Bolt check
Posted: Sun Jul 04, 2021 4:24 pm
by Techmaven
Both bolts tightened up fine..It looks like someone forgot to tighten them in the past..threads seem fine.
Re: Bolt check
Posted: Sun Jul 04, 2021 4:38 pm
by CudaMan
The heads of the two lower ball cap bolts should be wired together:
http://www.mtfca.com/discus/messages/41 ... 1393081993
The upper two bolts have castle nuts and a cotter pin.
Re: Bolt check
Posted: Sun Jul 04, 2021 6:36 pm
by Techmaven
John kuehn wrote: ↑Sun Jul 04, 2021 4:10 pm
Some of it IS silicone...I'm thinking I should disassemble and clean up that area.
Re: Bolt check
Posted: Sun Jul 04, 2021 10:49 pm
That little unused clip bolted to the frame should have a fuel line running through it.
