Ford Fathful oiler with exit tube on the left
Posted: Mon Jul 05, 2021 1:15 pm
by Mark Gregush
No connection, but something different;
https://www.ebay.com/itm/184918488678?h ... 000%7C7000
Never seen one of these before.
Re: Ford Fathful oiler with exit tube on the left
Posted: Mon Jul 05, 2021 1:42 pm
by RajoRacer
Perhaps right hand drive ? Be pretty crowded going off the right with the pedals & linkage in the way !
Posted: Mon Jul 05, 2021 2:31 pm
by BobShirleyAtlantaTx
I’m betting this was on a counter clockwise marine application. I’ve seen one in my life, the thing ran backwards. I assume the only difference, if they use straight cut timing gears would be camshaft, starter and internal oil line.
Posted: Mon Jul 05, 2021 3:07 pm
by Scott_Conger
If you study the oil capture system, you'll realize it is independent and indifferent to direction of engine rotation.
Posted: Mon Jul 05, 2021 3:51 pm
by SurveyKing
[scott
Are you saying that it would work effectivelygoing out the left?? /size]
Posted: Mon Jul 05, 2021 3:55 pm
by RajoRacer
The "capture" screened funnel/spillway is facing forward towards the magnets so a considerable amount of oil is captured & directed to the outlet - doesn't matter which side the fitting is - gravity does the rest !
Posted: Mon Jul 05, 2021 4:40 pm
by Scott_Conger
Daniel
Yes, and for the reason that Steve T stated
whether or not an individual finds the left facing outlet a feature or a folly would be up to them
Posted: Mon Jul 05, 2021 4:58 pm
by RajoRacer
Your observation & explanation was waaaay more "refined" Scott - I didn't mean to interject
Posted: Mon Jul 05, 2021 6:24 pm
by Scott_Conger
Steve
not understanding the embarrass-face...no offense was taken! I articulated a conclusion and you supplied the explanation
