What to use for a pressure gauge?
Posted: Wed Jul 07, 2021 4:00 pm
by schwabd1
I'm working on a speedster and want to use a pressurized fuel system with a hand pump. Where can I get a pressure gauge that will read that low? I'm guessing I want something that reads 0-5 lbs. What should the pressure be on a sealed unit? 1-2 lbs?
Re: What to use for a pressuren gauge?
Posted: Wed Jul 07, 2021 4:43 pm
Posted: Wed Jul 07, 2021 4:45 pm
by Tim Williams
1-2 lbs is good for a hand pump. They make modern low fuel pressure guages. The old vintage ones can get pretty steep in price.
Tim
Posted: Wed Jul 07, 2021 10:01 pm
by TMiller6
Look at ATV tire gages on Amazon and places like Dennis Kirk. Typically brass with 0-10 or 0-15 psi scales.
Re: What to use for a pressure gauge?
Posted: Thu Jul 08, 2021 8:33 pm
by Been Here Before
Posted: Fri Jul 09, 2021 12:34 am
by ModelTWoods
"Never been there; done that", but could an oil pressure gauge that was calibrated low, work? The Dodges from the 1920's used a low calibrated oil pressure gauge.
Posted: Fri Jul 09, 2021 9:47 am
by John Codman
Grainger has one that is 0 - 5PSI ( item # 18C790) but it's $35.
