1927 Touring top iron Pivot bolt question
Posted: Sat Jul 10, 2021 6:54 pm
My car has threaded rod and nuts for the pivot bolts for the top iron, I bought Pivot bolts from Snyder's T-3861 "Top Iron Mounting Studs" They are longer which I was hoping for but I can't pull the top out far enough to get it off the old stud, I'm trying with the top down if that matters.
Is there a trick to this, can anyone tell me what the dimension should be from pivot eyelet to pivot eyelet, also do I have the new stud in the correct orientation?
