Installing Rajo oil level indicator
Topic author - Posts: 102
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
- MTFCA Number: 21108
I installed the Rajo oil indicator from T. Mosher, put in 4 qts of fresh oil - no movement of the indicator, how much xtra oil needs to be added? Thanks
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Installing Rajo oil level indicator
I bet if you contact Tim , he can answer your questions. 4 qts should be full. Its a little over full on mine.
- First Name: Dennis
- Last Name: Seth
Perhaps there is air trapped in the system. You may have to bleed it out.
- First Name: Neal
- Last Name: Willford
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1915 Runabout
- MTFCA Number: 50256
When I installed mine, I left the upper petcock open and let the excess bleed off.
- Last Name: Codman
I have found that four quarts fills mine right to the top petcock. I have also found that engine oil leakage and consumption is virtually zero. I don't even check the oil level between changes (it leaks enough rear axle oil to make up for it).
BYW: Does anyone know where I can purchase 600W gear oil? None of the local auto parts stores seem to have it, and I am not paying $12.50 to ship a quart of oil.
- First Name: Danny
- Last Name: Deaton
Is the float in a bind? May need tweaking
- Last Name: Morsher
I contacted John, and all is well.
- MTFCA Number: 14383
Soooo what was the problem?
The problem with the Rajo oil indicator was just air trapped, everything working fine... nice quality accessory. Thanks John
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
- MTFCA Number: 32419
I always get "hey what is that" when I lift the right hood side and guys are checking out the engine. I love it and the day/night tank guage as well.
- First Name: Ronald
- Last Name: Bakow
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
- MTFCI Number: 25350
Never did see a Ranjo oil indictor but someone installed a dip stick on my 1915 Touring car. It goes to the lower engine oil plug and comes out at the top of the firewall on the right side under the hood. Works great but it has a modern T plastic handle that I want to chance for a simple metal loop to pull on.
