Overheating Or . . . Not.
Posted: Thu Jul 15, 2021 2:12 pm
by paddy1998
Yesterday I took my <23 Touring out for an extended drive 6 miles out and then 6 miles back. It's the first real extended drive I've done. Some stop and go, but mostly in high gear.
It took about 3 miles for the temp on the motometer to get into the circle, then it steadily climbed up to the top of the meter just as I was arriving at my destination.
When I got out and examined it I observed no steam coming out of the overflow or anywhere else, and no signs of the telltale gurgling that I heard on other occasions when overheated.
I'm running distilled water and Water Wetter.
Normal? Too hot?
Re: Overheating Or . . . Not.
Posted: Thu Jul 15, 2021 4:45 pm
That sounds normal to me. If the system is full of coolant and is not boiling and spewing water and steam, you are OK. I have a T with a modern type temperature gauge on the water outlet. It routinely shows 210 to 230 on the gauge, but there is never any sign of boiling or coolant loss or any other sign of overheating. I conclude that the gauge is somewhat in error. Regardless of the gauge, I've driven the car several thousand miles in warm to hot weather at highway speeds with no boiling or coolant loss. If your car performs well and responds normally to the engine controls and rolls freely with no evidence of brake drag or transmission bands dragging and does not boil over, you're in good shape. A T will run around 200 F in summer weather. Unless you add a water pump, the engine has to get rather warm for coolant to begin circulating. Many experienced T people here do not recommend water pumps. I don't have one, and since there is no indication one is needed, I'll do without.
Posted: Thu Jul 15, 2021 9:03 pm
After the car cools off, check the water level. If it is at least halfway up the top tank, it is fine. If it runs dry of coolant and overheats you run the risk of seizing the engine. That will damage the cylinders. I would expect the motometer is inacurrate. On my car it runs right in the center of the circle in hot weather.
Posted: Thu Jul 15, 2021 10:02 pm
There's a difference between real boiling, with steam, and a little gurgle after shut down. The first is a problem. The latter is normal, and not a problem. If you have real boiling: http://dauntlessgeezer.com/DG96.html
Posted: Fri Jul 16, 2021 10:44 am
by Rich Bingham
TXGOAT2 wrote: ↑Thu Jul 15, 2021 4:45 pm
. . . I have a T with a modern type temperature gauge on the water outlet. It routinely shows 210 to 230 on the gauge, but there is never any sign of boiling or coolant loss or any other sign of overheating . . .
Probably an optimal temp for thermosyphon function. It would be instructive to read the temp on the block inlet. When a T
really overheats, Old Faithful can look tame by comparison.
Posted: Fri Jul 16, 2021 11:53 am
by John Illinois
A note about water wetter. I used Water Wetter and distilled water in a Model A one summer. Just seemed like a good idea.
The block got very badly rusted. I had to clean it with rust remover.
I did not follow the directions which state use AT LEAST 15% ANTIFREEZE for street vehicles. By itself it will not protect against rust on iron.
I now just use 50/50 green antifreeze in my antique cars.
John
