UPDATE : Tire Slippage With McClaren Wire Wheels
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Tue Jul 20, 2021 2:53 pm
Just a quick note to let you know how my "fix" for tire slippage is working.
Changing from Universal T Drivers to Firestone Tires and coating the inside of the Clincher rim with pickup bed liner has stopped tire slippage on my T.
I am using 60 - 65 PSI inflation.
I have driven my T on several excursions and a day long tour and everything is holding in place.
The more I drive my T, the more confident I am that The problem is solved.
Here is a link to my original post.
viewtopic.php?f=2&t=13729&p=103760&hili ... ge#p103760
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
Re: UPDATE : Tire Slippage With McClaren Wire Wheels
Post by Scott_Conger » Tue Jul 20, 2021 3:11 pm
Bob
this is superb that you followed up on this!
and congratulations...that was a lot of work and expense
NH Full Flow Float Valves
Post by Allan » Tue Jul 20, 2021 10:05 pm
Well done Bob. The slippage was likely as a result of a combination of slick new rims and a narrower bead on the current tyre offerings. You fixed it by addressing the slick rim.
If anyone has a similar problem, there may be another way to address it. When I cut rim liners from the outside diameter of a 13" inner tube, I cut that strip wide enough that the edges fall under the rolled edge of the rim. When the tyre is fitted and inflated, the narrower modern bead jams down on the liner in the rim bead. This makes the tyre bead a firmer fit in the rim, and the rubber -to- rubber fit addresses the slick factor at the same time.
Hope this helps.
