Differential ring gear carrier
John L
Last Name: Leffler
* REQUIRED* Type and Year of Model Ts owned: 1923 Coupe, 1927 Touring
MTFCA Number: 22526
Post by John L » Fri Jul 23, 2021 3:22 pm
How do you replace the small studs on the ring carrier that hold the trust washers?
MTFCA Number: 14383
Re: Differential ring gear carrier
Post by speedytinc » Fri Jul 23, 2021 3:47 pm
I center punch & drill successively larger thru holes. Before I get to the pin's o.d. it releases & spins. Pick out the chips. Be careful to not drill into the body any deeper than originally. Before putting in the new pins, confirm by measuring, that the pin will end up @ the height. If you dont hit it right, get the drills back out.
* REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Jul 23, 2021 4:20 pm
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Jul 23, 2021 4:28 pm
Drill the center and use a small e-z out to twist them out- works pretty well and no chance of damaging the carrier. The press fit is not that tight.
Bill Coyle
First Name: Bill
Last Name: Coyle
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
MTFCI Number: 24067
Post by Bill Coyle » Fri Jul 23, 2021 7:12 pm
I've used the same method Donnie Brown used (In Dan's post) #10-32 screw to pull them out. I've done two rear axles that way with no issues.
The pins i purchased back then were 2 thousandths smaller than the originals and had no press fit. So I made mine on the lathe out of 5/16 bolts the same diameter as the originals .282". Also if you need to add a shim under the steel plate you can make the pin a little longer for better engagement. Bill Coyle
