UPDATE : A Solution To An Old Problem With Firewall Bracket Hardware
Posted: Wed Jul 28, 2021 10:02 pm
I am in the process of adding a starter to my 1916 T.
One problem I see coming up is the level of difficulty to install the firewall bracket nuts,
especially on the side where the starter will be.
I did it once on a '15 T with a starter and it was no fun.
So, I made these "nut plates".
I threaded two 3/8" - 24 holes in a 1/2" piece of steel.
They are spaced two inches on center to match the firewall bracket.
The block is held in place with a 1/4" - 20 countersunk screw.
Now the firewall can be mounted with a couple 3/8" - 24 bolts and lock-washers.
As this is untreated steel, I will use some anti-seize on all of the hardware.
This could be accomplished several different ways.
A couple of nuts could be welded to a plate or even directly to the frame.
Hopes this helps.
[/size][/b]
Hopes this helps.
[/size][/b]
