15 gas tank venting
Topic author - Posts: 178
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
15 gas tank venting
I was being frustrated by the way my 15 ran great on some days and then seemed to lack power on hills others. After lots of forum reading I decided to look at the vent in the gas cap. The hole in the top was clearly plugged. Depending on how tight I tighten the cap was causing the problem. Such a simple problem to over look. Thank you forum members.
Re: 15 gas tank venting
Had a mechanic that worked for me before I retired, he always said "start with the easy things first"...it's usually something like that. Glad this was the case for you!
