Vaporizer Display
Topic author - Posts: 12
- First Name: Hurst
- Last Name: Barbee
- * REQUIRED* Type and Year of Model Ts owned: 1927 Runabout with Pickup Body
Vaporizer Display
After installing the Holley NH conversion kit from Lang's, I restored the Vaporizer and decided to keep it as a display piece. Attached is a picture. Also, if I ever sold the '27 Model T, then the new owner may need it if they wanted to go back to it for some reason.
I was wondering which is more common, the Ford labeled unit like this one or the Holley version?
Hurst
Hurst
- MTFCA Number: 52564
Re: Vaporizer Display
That one, which is the Holley. The other one was the Kingston, which is way less common.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 14972
- MTFCI Number: 15411
The Vaporizer had both "Ford" and/or "Holley" name tags - Kingston Regenerator was a different animal !
- Last Name: House
- MTFCA Number: 115
Steve is right. Holley production couldn’t keep up with Ford T s in 1927 so an agreement was reached allowing Ford to copy the Holley design and affix their own brass ID tag.
I don’t know why I turned out this way. My parents were decent people
Same with the NH, some have Holley some have Ford tags.
1920 Dodge touring
1920 Dodge touring
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
- MTFCA Number: 2406
- MTFCI Number: 22213
Some of the 1927 Model Ts came with Kingston vaporizers, but they were B-1 Gasifiers, not Regenerators. The Kingston Regenerators were a model made for the aftermarket and were advertised already in 1924 in the Ford Owner and Dealer magazine.
1922 Coupe , 1926 Touring
Appreciate the correction, Jim !
- First Name: Erik
- Last Name: Barrett
Hanging on a wall is what vaporizers do best.
- First Name: Chris
- Last Name: Barker
All fine, but was the conversion worth doing? Does it make any difference?
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
Gorgeous!
They do work when good.
