I finally installed my I-timer
Posted: Thu Aug 05, 2021 1:12 pm
For me it was a two man job. I could not crank and hold my finger over #1 hole to check for TDC.
The first step was to measure the pulley on the crankshaft. I have a modern pulley and I measured it by wrapping a string around it. 11 inches divided by 3.14 = 3.5 inches. I know I have a 3.5 inch pulley and that dimension is needed later in setting up the timer.
Next step was to find TDC. We kept cranking too far around so we pulled out my nifty TW components Accurate Timing Indicator It made life easier and also measures degrees past TDC. Turns out my pulley also had a seam when the engine was at TDC, so everything was being double checked as we did the installation.
The roller (Vane Actuator Assembly) is installed first. To measure and make sure it was installed correctly I borrowed a plastic ruler from my kids. I cut it so I had a 3 inch ruler. I wonder if they will want it back. The vane actuator fit well, so now to the timer. It fit well, also. That was expected.
The timer rod gave us the most trouble. Even though the engine ran well, we definitely had to adjust the timer rod. We made at least 6 trips to the basement to bend the rod. A timer rod needs to be twisted as you bend it. You cannot just straighten it.
The #1 spark plug should fire at 15 degrees past TDC. We measured it with the timing indicator, the seam in the pulley, and the pin holding the pulley on the crankshaft. Once we were satisfied it was correct, it was time to start the car.
My engine was rebuilt 3 years ago and had been driven from Milwaukee to Detroit 2 years ago, so we know it was in good shape. The coils were adjusted with my ECCT. So coils, timer, and engine all ready to go. We took it for a ride around the neighborhood and she sounded better than ever. Much smoother than she ran with the Anderson timer. But the real test would be on a tour.
A week later I joined the Dairyland Tin Lizzies group on their Carousel Tour of about 130 miles. She ran better than ever. Nice and smooth. Started right up every time, but I figured the real test was going up a hill. Every time we reached a hill I upped the throttle, and she rode the hill like I had turned on the cruise control. Amazing. I did not have to adjust the throttle or the timing.
The old Anderson timer has been relegated to the trunk. You never know if something will happen and you will need it, or maybe someone else will . Never hurts to carry a spare.
