T in front of the serial number
Posted: Mon Aug 09, 2021 5:01 pm
by Mike Royster
I have heard of the B stamped blocks in certain years but came across a block stamped T in front of the 6 digit serial number today. Does the T designate anything in particular?
Re: T in front of the serial number
Posted: Mon Aug 09, 2021 7:40 pm
by Wayne Sheldon
Probably a replacement block.
Posted: Mon Aug 09, 2021 7:56 pm
by Mark Gregush
With more information, like approx year of block, can only speculate that it might have had the number ground off, and the number now on it was a builder's number.
Posted: Mon Aug 09, 2021 7:59 pm
by Wayne Sheldon
A six digit number? Would indicate pre1916. Some periods of years, replacement blocks were marked with two "Ford" scripts stamped on the serial number embossment. A lot of minor and a few major changes were made across the seventeen years of model T blocks. Casting dates were used on USA cast blocks from 1908 into some 1921. These things can all help to date a block to see if the serial number and block are the same vintage.
It could also be possible that it could be a "backdoor" engine block. Ford sold thousands of motors for industrial, marine, and agricultural uses. Often, but not always, those engines had serial numbers stamped on them by the company purchasing the "backdoor" engine from Ford. Usually, those serial numbers followed a couple letters. I don't recall any offhand following a single letter, but it may be possible? And "backdoor" engines rarely had more than five digit serial numbers.
Posted: Mon Aug 09, 2021 8:31 pm
by Mike Royster
Yes it is pre 16 and brass radiator, serial number T 281982, which puts it at May of 1913. I suspect it is a replacement block as well.
Posted: Mon Aug 09, 2021 10:22 pm
by Wayne Sheldon
Can you roughly tell the vintage of the block? A lot of blocks got replaced early on due to people not being used to blocks freezing in the winter. If the block appears to be only about a year newer or less, it shouldn't even affect its HCCA acceptability. Model T clubs tend to be more lax and not mind newer engines in older models.
Is the block set up for a generator mounting on its right side? A pre-generator block would at least look close to correct.
Posted: Tue Aug 10, 2021 12:08 am
by Steve Jelf
The encyclopedia lists a good many engine details and changes that could help you determine pretty closely the year of your block.
http://dauntlessgeezer.com/DG80.html
Posted: Tue Aug 10, 2021 10:43 am
by Mike Royster
Thanks all, I appreciate the assistance!
