				12 volt Alternator?
				Posted: Thu Sep 02, 2021 11:37 am
				by Oldav8tor
				Does anyone know who makes the 12 volt alternator that is a direct replacement for the gear-driven six volt generators on later Model T's?  I know the vendors sell them but wonder who they get them from?
				Re: !2 volt Alternator?
				Posted: Thu Sep 02, 2021 12:03 pm
				by speedytinc
				Be aware of high failure rates. 1) the gear is pinned with a C pin. They tend to  shear & fall into the motor. 2) They need good air flow to cool. Without a fanned pulley & the obstruction from the mount, they run hot & can burn up. A buddy had one go bad. It let the smoke out of the generator wire to the firewall & switch. Really ugly.
You can run a stock T generator. Just reset the output to 1/2. It doesnt care what voltage its charging.
You are working real hard to change your T to 12V because of a poor starter. Its the starter, not your high compression head.
Easier & cheaper : 8V battery. Every thing will work on 8V. No other changes necessary, maybe lower generator output. 8V will compensate for that weak starter.
				Posted: Thu Sep 02, 2021 1:38 pm
				by Oldav8tor
				My car has no generator or alternator and runs a 12 volt geared starter. The Hot Shot charger from John Regan keeps my 12 volt odyssey battery charged at 90+%. I’m researching for a friend who wants to know his options before deciding which way to go. I appreciate you sharing the potential problems with the alternator....those are the things he needs to know.
				Posted: Thu Sep 02, 2021 2:01 pm
				by George Hand
				I needed one bad a couple years ago, Langs were on BO, Macs had one & I bought it. I think they come from Buckeye Auto Electric in OHIO, they use a core with an internal fan so they should last longer that the Texas T alternators that used a older Delco core that was made for an External Fan. George.
				Posted: Thu Sep 02, 2021 2:30 pm
				by Scott_Conger
				Or, Heaven Forbid, put a generator on the car. So long as you're not buying a $65 Krylon rebuild off of eBay and stick to known members/vendors, you can put a piece of equipment on your car which will pretty much outlast you, and not look like something that came off of a Kia.
				Posted: Thu Sep 02, 2021 3:52 pm
				by Nunsio1
				Tim, just ordered my replacement 12 volt alternator from Buckeye Antique Auto Electric $235.00 — they supply Langs, Snyders’s etc.
John Monticciolo
Oscoda Michigan
1924 C Cab
				Posted: Thu Sep 02, 2021 4:29 pm
				by speedytinc
				BTW the langs unit has a "texas T parts" name casting.
				Posted: Thu Sep 02, 2021 8:11 pm
				by Cap
				My Texas T 12 Volt Alt has been running from ~2010..  no problems.. Put it in so I could run Christmas lites off of an Inverter..  Left it and the Inverter in the TT.. Handy
Cap
				Posted: Thu Sep 02, 2021 8:31 pm
				by HalSched
				In aprox 2000 I installed a Nissan alternator on my Fordor and have had "0" problems.
				Posted: Thu Sep 02, 2021 8:42 pm
				by Cap
				HalSched wrote: ↑Thu Sep 02, 2021 8:31 pm
Belt on the Left side or Gear from the Right?..
Cap
				Posted: Fri Sep 03, 2021 12:00 am
				by HalSched
				Belt on px side.  Oil pump in gererator hole for pressure mains.  AC compressor on Px side and alternator mounted on top of compressor.  All riven with one serpentine belt.  Works great!
				Posted: Fri Sep 03, 2021 7:59 am
				by Cap
				HalSched wrote: ↑Fri Sep 03, 2021 12:00 am
I'd love to see a pic of that install!..
Wife wants AC in her T (yet to be purchased).. I'd like to also see the condenser mount..
Cap
