26/27 Brake equalizer kit - RHD?
Posted: Mon Sep 06, 2021 7:49 am
by Rata Road
Does anybody know if the brake equalizer kits for a large drum can be fitted to a RHD car?
If so do you just invert the system or does it require modification.
Re: 26/27 Brake equalizer kit - RHD?
Posted: Tue Sep 07, 2021 1:36 am
by Rata Road
Doesn't anybody know?
Posted: Tue Sep 07, 2021 5:55 am
Kevin, my experience when fitting Bennett brakes to my 1917 shooting brake, the equaliser I bought from Snyder's as simply sapped end for end across the frame. At worst, a LHD one will show you how it works, and offer a way modify it if needed.
Hope this helps.
Posted: Tue Sep 07, 2021 8:24 am
by Henry K. Lee
Pretty easy to fabricate one to your liking using an old donor forward brake cross over. Cut down and install forward of the existing one with a float attachment. Sorry I did not take photos years back.
Posted: Tue Sep 07, 2021 9:11 am
by Humblej
I have one on my LHD 1926 T. The part itself looks like it could be installed either LHD or RHD, but I cannot say if it will interface with RHD components or interfere with the exhaust pipe. My best GUESS is it would work for RHD.
Posted: Tue Sep 07, 2021 5:21 pm
by Rata Road
Ok thanks guys.
So expensive to freight to NZ I wanted to be sure it would work.
Posted: Tue Sep 07, 2021 5:35 pm
Make your own out of 3/4 inch rod. I made one like the one shown in the link. I didn't use the short bar with levers for the equalizer, just a piece of flat stock. Worked fine on my 21 with AC/Rocky Mt brakes and on at least 2 other cars that I have installed them on.
http://www.mtfca.com/discus/messages/33 ... 1381763908
Nice thing about this type, the swing can be made to go under an add-on transmission.
Posted: Wed Sep 08, 2021 7:55 pm
by Rata Road
Thanks Mark. I would rather have them made here.
Is there any detailed drawing available?
I have a LHD car also so either type drawing would be great.
Kevin
Posted: Wed Sep 08, 2021 10:14 pm
No drawing, I just winged it when I made mine. I will try and dig one out tomorrow and take a few snaps and dimensions.
Posted: Wed Sep 08, 2021 11:44 pm
by Rata Road
Brilliant
Posted: Thu Sep 09, 2021 12:55 pm
All dimensions are approx. 11" across, 4" from top clevis hole to center of parking brake cross shaft, 6" to center of sliding crossbar. Tab to mount equalizer, 2 1/2" flat stock by 4" long. Equalizer bar 10" center to center for clevis pinholes 1-1/2" flat stock. I bent the ends down on the first ones I make, but found worked just fine leaving flat. For the adjustable rod between the brake pedal and equalizer, notched it using a saws-all to fit the clevis I was using, allowing a bit of wiggle room. For mounting to parking brake cross shaft, U-bolts were used. Do not need an eazy-slider with this setup, it clears the pan and dip in the parking brake cross shaft, so does not move the brake pedal when parking brake is applied.
Posted: Thu Sep 09, 2021 12:57 pm
The force torque should be about the same as the equalizer sold. Mounted on the car;
Posted: Thu Sep 09, 2021 5:50 pm
by Rata Road
Thanks so much Mark for all the effort you have put in.
Brilliant.
Kevin
Posted: Thu Sep 09, 2021 7:38 pm
You are welcome. Love that word, "Brilliant", it can be used in so many ways! :D or :roll:
Posted: Fri Sep 10, 2021 10:08 am
Forgot the thickness of the flat plate, I used 1/4 inch. For the bolt at the equalizer, I used 1/2 inch fine thread with unthreaded shoulder and bronze/brass washers between, drilled and locked with cotter/split pin.
Posted: Fri Sep 10, 2021 5:10 pm
by Rata Road
Ok got it
