Flywheel ???
Posted: Wed Sep 08, 2021 3:04 pm
by Dan Hatch
Anyone ever see a flywheel like this? Has 4 of these, each 90 degrees from each other. Ring gear has same but a counterbore to fit the raised sleeve. Have not tried to see if the “sleeve “ is removable. Does any one know.
Customer brought this to me to rebuild, but looks like he will need a flywheel.
Input???
Thanks Dan
Re: Flywheel ???
Posted: Wed Sep 08, 2021 3:09 pm
by speedytinc
YE YES YES. Its a 19. possibly to early 20. One of those really unique 19 features.
Sleeves are removable.
Re: Flywheel ???
Posted: Wed Sep 08, 2021 3:17 pm
by Dan Hatch
Was thinking that was the story.
Guess I should save the ring gear for humanity??
NOT! Thanks Dan
Re: Flywheel ???
Posted: Wed Sep 08, 2021 4:17 pm
by Jerry VanOoteghem
If the flywheel is in otherwise good shape, and you don't want to use those sleeves, you could just grind them flush and use a standard ring gear.
Re: Flywheel ???
Posted: Wed Sep 08, 2021 5:26 pm
by Scott_Conger
or you could easily modify the new ring gear and let the next guy in 50 years see how '19 cars were built...
Re: Flywheel ???
Posted: Wed Sep 08, 2021 9:08 pm
Scott_Conger wrote: ↑Wed Sep 08, 2021 5:26 pm
Well yes, that too. I only mention the other option since he was leaning towards junking the existing flywheel.
Re: Flywheel ???
Posted: Wed Sep 08, 2021 10:11 pm
by Mark Gregush
No, he was leaning towards junking the ring gear!
Re: Flywheel ???
Posted: Thu Sep 09, 2021 10:00 am
by Dan Hatch
I am going to try and use flywheel.
I was talking about junking the ring gear.
Re: Flywheel ???
Posted: Thu Sep 09, 2021 10:16 am
by Scott_Conger
I gotta work on that reading comprehension stuff!
Re: Flywheel ???
Posted: Thu Sep 09, 2021 11:53 am
Dan Hatch wrote: ↑Thu Sep 09, 2021 10:00 am
Dan,
"Customer brought this to me to rebuild, but looks like he will need a flywheel."
