Victor 2 Gas headlight door
AndreFordT
First Name: Andre
Last Name: Valkenaers
MTFCA Number: 23792
MTFCI Number: 19330
Post by AndreFordT » Thu Sep 16, 2021 3:23 am
I am looking for a usable headlight door for one of the Victor 2 gas headlights on the 1914 runabout.
Can some one help me?
(This is also posted on the parts part of the forum)
Andre
Belgium
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: Victor 2 Gas headlight door
Post by R.V.Anderson » Thu Sep 16, 2021 3:26 pm
Andre, I bought new ones from the vendors and transferred the hardware from the originals to them. I was very happy with how they came out. Perfect fit.
Hudson29
First Name: Paul
Last Name: O'Neil
MTFCI Number: 18018
Post by Hudson29 » Thu Sep 16, 2021 7:42 pm
Chaffin's had these parts a few months ago.
RV - how did you accurately transfer the hardware? I need to do this but was worried about getting everything back in the right place.
Paul
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Thu Sep 16, 2021 8:33 pm
It's quite simple. Since the rim is uniform, first install the door half of the hinge into the steel half in the bucket and put the rim in place on the bucket any old way. Then drill one rivet hole and install a small machine screw and nut, either a #4 or a #6, I forget which. Tighten the nut, make any adjustments needed, then drill the other holes and install screws there too. Put the rim in place again on the bucket, then put the latch in place and tighten the big knurled nut to hold it while you repeat the hinge drilling and screw/nut procedure. Once both hinge and latch are mounted and adjusted for smooth operation, drive out the hinge pin and take the door over to the bench vise that has a good sized punch installed in it vertically, to serve as a rivet buck. Then remove one screw at a time and replace it with a rivet. I recommend annealing the rivets; makes it night and day easier. If you need the rivets let me know; I had to buy a pound of them as I recall and they must still be around here somewhere.
AndreFordT
First Name: Andre
MTFCA Number: 23792
MTFCI Number: 19330
Post by AndreFordT » Fri Sep 17, 2021 1:41 pm
Thanks R.V. for the information and the help with the way to set the door on the light.
At this time I just need to finish (Payment) the order of the door and a few other parts at Chaffins Garage.
Andre
Belgium
Hudson29
First Name: Paul
Last Name: O'Neil
MTFCI Number: 18018
Post by Hudson29 » Fri Sep 17, 2021 4:24 pm
Thanks RV, I have made note of the procedure. It may be a couple of months before I get to this as I have a number of other projects ahead of that job. I like the idea of using nuts & bolts to get everything lined up. I have never done any riveting so this will be a learning process.
Paul
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Fri Sep 17, 2021 7:54 pm
Well, Paul, the only real trick is to anneal the rivets. Once that's done, you won't believe how easy it is.
