Outer Muffler Shell
Topic author - Posts: 213
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
- MTFCA Number: 21458
Outer Muffler Shell
I did some measuring several years ago but can't remember. Will a 5 inch truck exhaust pipe fit inside the ends for a T muffler? It would definitly be thicker than the stove pipe metal that was on most mufflers.
- First Name: Greg
- Last Name: Kuhnash
- * REQUIRED* Type and Year of Model Ts owned: 1917, 1921 touring 1927 RPU
- MTFCA Number: 28086
- MTFCI Number: 21773
- Board Member Since: 2006
Re: Outer Muffler Shell
Yes it works very well.
I used the pressed still ends but I think the cast ends would work better.
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
- Last Name: Kramer
- * REQUIRED* Type and Year of Model Ts owned: 3
I have repaired several blown out mufflers that way
- MTFCA Number: 52564
Cast type ends; There is a taper to the ridge the outer shell fits onto. When the muffler is assembled and through bolt is pulled up, the ends of the outer tube get slightly flared to seal. The minimum OD on the cast ends is about 5" at the end and approx 5-3/16" at the bottom, so ID on the 5" pipe would be too small.
1920 Dodge touring
1920 Dodge touring
