Outer Muffler Shell
Posted: Mon Sep 20, 2021 10:43 pm
by Dennis_Brown
I did some measuring several years ago but can't remember. Will a 5 inch truck exhaust pipe fit inside the ends for a T muffler? It would definitly be thicker than the stove pipe metal that was on most mufflers.
Re: Outer Muffler Shell
Posted: Tue Sep 21, 2021 7:54 am
by Kuhner
Yes it works very well.
I used the pressed still ends but I think the cast ends would work better.
Posted: Tue Sep 21, 2021 8:49 am
by Farmer J
I have repaired several blown out mufflers that way
Posted: Tue Sep 21, 2021 12:13 pm
Cast type ends; There is a taper to the ridge the outer shell fits onto. When the muffler is assembled and through bolt is pulled up, the ends of the outer tube get slightly flared to seal. The minimum OD on the cast ends is about 5" at the end and approx 5-3/16" at the bottom, so ID on the 5" pipe would be too small.
