Jack rabbit clutch question
Posted: Fri Mar 22, 2019 9:05 pm
by RGould1910
I discovered I have a number of Jack rabbit clutch discs but don't know if it is a full set. I have eight of them. Is this the right number for a 27 transmission, coupled of course with the right number of outer discs?
Re: Jack rabbit clutch question
Posted: Fri Mar 22, 2019 9:11 pm
by Jack Putnam, in Ohio
Nine are in a full deck!
Posted: Sat Mar 23, 2019 12:30 am
by Kerry
Jack and turbo for what I can remember, are set up with the small disc and 8 is the right number, 10 to 11 big Ford discs, the watts used the fibre big discs and small Ford discs.
Posted: Sat Mar 23, 2019 9:31 am
by Allan
8 pr 9 will do. The important thing to remember is that the finished stack needs to be the same thickness as the standard Ford clutch pack. This may mean adding an extra Ford disc or two to make up the difference.
Hope this helps.
Allan from down nunder.
Posted: Sat Mar 23, 2019 12:44 pm
by Mark Gregush
Posted: Sun Mar 24, 2019 10:00 am
by RGould1910
Thanks for the input. Didn't know about instructions being available on line . Very helpful.
