Guy Building his Own 1913 Touring Body from Scratch
Posted: Tue Sep 28, 2021 8:24 am
by CudaMan
Re: Guy Building his Own 1913 Touring Body from Scratch
Posted: Tue Sep 28, 2021 12:48 pm
by Rich Eagle
Thanks for linking this Mark. It's easy to say "I wouldn't do it that way". The point is that he is using techniques that he is familiar with and that work for him. The results are pretty impressive and he can clean it up to make it look darn good. Also, he has taken the time to share it with us. Seeing it is inspiring and we can learn more from others ideas.
Posted: Sat Oct 16, 2021 7:25 am
by CudaMan
Posted: Fri Oct 22, 2021 10:33 am
by TonyB
When I built my 1917 touring, the metal mostly OK but the wood had disappeared I was advised not to build the wood frame on the chassis but on a flat piece of 3/4” plywood to make sure it was all flat. The chassis flexes and may not even be square, so getting panels correct would be very tough.
Maybe he checked his chassis but was still on four wheels so he is relying on the springs being correct. Mine were not. I also had the same problem on the 1909 touring.
His skills look really good but I’m concerned about the front cowl not being quite square.
Posted: Sat Oct 23, 2021 10:55 pm
by Duckwing
What impresses me the most is that he works in flip flops.
