repairs to a botched distributor installation
Dave_Kriegel
First Name: David
Last Name: Kriegel
* REQUIRED* Type and Year of Model Ts owned: 1927 1926
MTFCA Number: 52627
Post by Dave_Kriegel » Tue Sep 28, 2021 8:31 am
Summary asked to help with an inherited Model T ( not mine)
Model T steering column LACKS / MISSING the attachments to attach to control rods for carburetor and distributor ONE attachment is there but it is up a few inches from the firewall !
So my question is " is there an after market piece I may purchase to replace the missing attachment points
I will check with Texas T to see if they sell attachment kit for distributor
To set timing say 2 degrees before top dead center on the distributor and keep it there from turning so I can get the engine running I am thinking of either securing the distributor base with a
1. spot of silicone
2. drill a small hole at base and put in a set screws or
3. make a small shaped wooden block to glue to the base of the distributor and block
THIS is why I do not like folks adding distributors vs the original design It just seems to complicate life The original system is so simple and easy to work with
any temporary fixes appreciated
MTFCA Number: 51486
Re: repairs to a botched distributor installation
Post by TXGOAT2 » Tue Sep 28, 2021 9:41 am
About what year is the car? Do you have a picture of it?
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Tue Sep 28, 2021 11:30 am
Langs sells a bolt on lever #6297 that might help you.
