Manifold gasket?
Posted: Sat Oct 02, 2021 8:44 am
by Oldav8tor
My friend is looking at replacing exhaust and intake manifold gaskets. I recall discussions where it was pointed out that some were better than others. I’m not at my laptop to research it so can somebody point us in the right direction?
Re: Manifold gasket?
Posted: Sat Oct 02, 2021 11:13 am
by jsaylor
The rings and Gland style are the best. If the exhaust manifold is straight, they will keep it from warping.
Posted: Sat Oct 02, 2021 11:40 am
Whatever type you use, be sure to place the glands between the manifold and the block. Especially so of the exhaust manifold. Exhaust manifolds get hot and the weight of the tail pipe tends to pull the back down. When it cools it stays deformed and will eventually sag so that you can't get a good seal. The glands will keep the back up and the center down so that it remains straight.
Posted: Sat Oct 02, 2021 12:13 pm
Many of the decisions on the manifold gasket choice have to do with the condition of the exhaust manifold. So you should check that first, it will make a difference on your purchase(s).
Most recent discussion https://mtfca.com/phpBB3/viewtopic.php? ... et#p170985
Other
https://www.google.com/search?client=fi ... sket+mtfca
http://www.mtfca.com/discus/messages/6/ ... 1058789647
