Question About Radiator Cap
Posted: Tue Oct 05, 2021 7:59 pm
by BLB27
Should there be a rubber gasket under the radiator cap?
Re: Question About Radiator Cap
Posted: Tue Oct 05, 2021 8:02 pm
by Humblej
A Ford stock radiator cap?
Posted: Tue Oct 05, 2021 10:16 pm
by DanTreace
Posted: Tue Oct 05, 2021 10:29 pm
by RajoRacer
It was a paper gasket, I believe - not rubber. If you have a motometer or a decorative cap, one could use a rubber gasket or an o-ring to assist in the proper alignment.
Posted: Tue Oct 05, 2021 10:40 pm
by Professor Fate
Lang's has the rubber gasket you need. [Order an extra for later.]
Posted: Tue Oct 05, 2021 11:07 pm
by KWTownsend
Or stop at your local hardware store, even the big box store, and get a drain gasket.
Posted: Tue Oct 05, 2021 11:18 pm
by Allan
The problem is the thin edge on the original radiator cap. When you screw the cap down, that thin edge engages right on the outside of any gasket used, and often the gasket is distorted and the cap doesn't seal anyway. If you can find one of the caps with the rolled in edge below the thread, you are on a winner.
I make my own, cut off the end of a red urethane boat trailer roller. They end up about 1/8" thick, have a smaller hole in the middle and thus do not so easily distort. My little finger pulls it out if ever I need to top up the radiator.
Posted: Wed Oct 06, 2021 1:28 am
by Craig Leach
Yes gasket, of some kind. unless you like cleaning the hood & windshield. Or goggles if you have Speedster.
Craig
Posted: Wed Oct 06, 2021 4:59 am
by Alan Long
Paper gaskets are rubbish. I use (and love) Part # 3927M from Lang’s.
It’s nice n thick, rounded end that fits nicely into the Radiator Neck, made of Neoprene and cost $1.65. Bargain.
As suggested by others it has a bit of compression to align the Cap or fancy wings or temperature gauges!
Easily flicked out when coolant topping up is needed. Get a couple
Alan in Western Australia
Posted: Wed Oct 06, 2021 9:59 am
by TRDxB2
Old thread suggest using a popup drain gasket as it is the same as sold by vendors and available in most hardware & ome Improvement stores
http://www.mtfca.com/discus/messages/59 ... 1460135057
Posted: Wed Oct 06, 2021 8:24 pm
by Professor Fate
I run my Lang's neoprene [sorry I called it rubber] gasket smooth side down. I have gotten 3-4 yrs out of a new one before replacement.
