The Most Complicated Gas Line You Will Ever See On A Model T (Final Update)
Topic author - Posts: 705
- First Name: Michael
- Last Name: Pawelek
This ‘25 Coupe had a total restoration 20 years ago. I have no idea what they were thinking. Getting the Carburetor off to clean out was a huge PIA. I will be replacing with a regular potato and one piece line. Enjoy!
Last edited by MichaelPawelek on Sat Oct 16, 2021 7:39 pm, edited 1 time in total.
- First Name: David
- Last Name: Sullivan
- * REQUIRED* Type and Year of Model Ts owned: 1923
Re: The Most Complicated Gas Line You Will Ever See On A Model T
Must have had stock in Imperial Brass..dave
The problem is that someone started at the tank and made all the runs and 90° bends to the carburetor not taking into consideration the carburetor would ever have to be taken off in the future. It is very stiff and precise but with no “Union” in the line.
- MTFCA Number: 14383
I am seeing 3 "union/couplings". Looks like a mess of compression ring fittings.
Someone had a can full of brass fittings needing a purpose.
The two near the carburetor actually have threads on the back sides and tighten up as you try to unthread them. I’ve never seen this type of fittings before.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
When non mechanically incline people betterize things. I see it every day.
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Probably worked at a hardware store.
- MTFCA Number: 52564
I saw a 1926/27 setup on Facebook (can't find the picture now), that had all kinds of twist, turns, dogleg and filter(s). They, too, took something so simple and over complicated it!
1920 Dodge touring
1920 Dodge touring
- First Name: Dennis
- Last Name: Seth
Perhaps his uncle was a plumber!
- Last Name: Codman
Rube Goldberg is alive and well.
- MTFCA Number: 51486
But... the installation is not complete!! It needs magnets and clothespins if it is ever to function properly... filters, filters, filters.... and where are the fuel pumps??
Funny you should mention clothes pins. Most folks under 50 wouldn’t know what they are. I still have a shoe box full I occasionally use to hold small parts and hang things on the wall. Also to hold gaskets in place as I Permatex them up. Save any old ones you have. Like everything else the newer ones are stupid worthless.
I came across a website of someone who is making real clothespins that actually hold together and work. I can't recall how to access it. Some searching might turn it up, if it still exists.
He probably had to take it off very often! There is no sediment bulb and I didn't see anything like a filter in the line. Lots of joints which could catch sediment though.
- Last Name: Codman
I have some that I actually use to pin clothes to a clothesline. The clothesline uses no electricity, and is (in the SW Florida sun) just about as fast as a clothesdryer.MichaelPawelek wrote: ↑Fri Oct 15, 2021 10:41 amFunny you should mention clothes pins. Most folks under 50 wouldn’t know what they are. I still have a shoe box full I occasionally use to hold small parts and hang things on the wall. Also to hold gaskets in place as I Permatex them up. Save any old ones you have. Like everything else the newer ones are stupid worthless.
- First Name: Adrian
- Last Name: Whiteman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Hey - It Works!
- First Name: Ed
- Last Name: Martin
I’ve seen several that look exactly like that. Every T I’ve bought in the past had similar” improvements” added to them in the past. I promptly remove them unless it’s a working era manufactured accessory. Otherwise it’s back to stock in order to make future troubleshooting easier.
If you add a fuel pump or two you can then add a fuel pressure regulator.... maybe do a 2 stage setup with a high and low pressure pump and 2 regulators!
Well, The ground up rebuild on this Model T was done 21 years ago by someone in San Diego so I can take no credit for all this added mess!
I am not sure which would be worse? That mess? Or four feet of rubber hose cobbled in?
Re: The Most Complicated Gas Line You Will Ever See On A Model T (Final Update)
Henry would approve.
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
Hi Michael
Looks Good !
FJ
Looks Good !
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
