Temperature gage
acereske
First Name: Al
Last Name: Cereske
* REQUIRED* Type and Year of Model Ts owned: ‘26 coupe
MTFCA Number: 51759
Temperature gage
Post by acereske » Thu Oct 14, 2021 12:44 pm
I have a ‘26 Ford Model T coupe and am interested in installing a temp gage inside the car with the sending unit inserted in the return radiator hose. Has anyone done this and what was the resulting benefit?
MTFCA Number: 24868
Re: Temperature gage
Post by Jerry VanOoteghem » Thu Oct 14, 2021 12:50 pm
I have not done it, but I have used motometers. The only real benefit might be peace of mind? The downside might be that its readings might be something to needlessly fret over. The only temp gauge I use anymore is the overflow tube. If steam is coming out of it, something's wrong. If not, we're all good.
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Oct 14, 2021 1:11 pm
This would be period correct and excess to my needs. To install the sender, ypu can use a model A lower radiator tube, or drill and tap one of the T inlet or outlet casting. I’ve seen guys install in a soft plug hole, too. kISS
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Thu Oct 14, 2021 1:40 pm
Hi Al,
Yes I use a SW mechanical gauge in the return pipe. The thing to remember is that this is the water coming out of the radiator and therefore cooler than the engine temperature. You need to establish the differance between the water coming out of the engine and the water going back in and add that to the gauge reading. A infared thermometer works good for this and has many other uses.
Craig.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Oct 14, 2021 1:53 pm
First try was with the Model A inlet that has the thread port. But that only read the cool motor :shock:
water temp forum.jpg (69.11 KiB) Viewed 2554 times
Then mounted to the upper outlet, that let the meter read correctly.
At norm temp when running at tour speed, not fast.
Fuzzy photo from running.
But at extreme speed, running with the modern traffic on 4 lane, likely doing 45mph + , the meter showed the work the engine was doing, generating a lot of heat from those hot pumping pistons :o
IMG_6882 (500x375).jpg (106.39 KiB) Viewed 2554 times
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Thu Oct 14, 2021 2:15 pm
Other than using a MotoMeter and if the radiator isn’t gurgling or not getting really hot your OK. To me once you have a heat gauge of some sort in your car you would wind up watching it all the time. I guess Ford thought your amp meter was enough to be concerned about when he started to install them in the late teens!
MTFCA Number: 51486
Post by TXGOAT2 » Thu Oct 14, 2021 3:07 pm
Coolant temperature gauges are normally installed at or near the water outlet. It's possible to have a cool inlet temperature reading with a hot or even boiling engine. A clogged or frozen radiator will do it. A low water situation could do it.
Ed Fuller
First Name: Ed
Last Name: Fuller
MTFCA Number: 29582
MTFCI Number: 22818
Board Member Since: 2012
Post by Ed Fuller » Thu Oct 14, 2021 4:38 pm
I installed a temperature gauge in the water outlet on my speedster very similar to how Dan did his. I had an old aftermarket water pump housing similar to a Nims pump. It was missing the shaft and impeller so I tapped the hole and installed the temperature bulb. Seems to work well.
MTFCA Number: 51486
Post by TXGOAT2 » Thu Oct 14, 2021 6:36 pm
I went for a drive this afternoon with temperatures in the mid 80s F. Car runs about 200 F indicated at the water outlet. I pulled over and stopped after about 10 miles of running at 45-50 MPH with a good hill climb included. After about 5 minutes, I could put my hand on the water inlet pipe comfortably. The engine and upper radiator tank were still way too hot to touch, let alone grasp and hold.
John Codman
Last Name: Codman
Post by John Codman » Fri Oct 15, 2021 10:01 am
No disrespect intended to anyone, but why would you put a temperature gauge in the engine inlet hose/pipe? This would give the driver no useful information as to the actual engine temperature.
MTFCA Number: 51486
Post by TXGOAT2 » Fri Oct 15, 2021 10:06 am
For the lowest inlet temperature obtainable, make sure your radiator is completely clogged.
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Oct 15, 2021 12:38 pm
I think Ed Fuller wins for the perfect install. JMHO. Great idea to use one of those water pump castings
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Fri Oct 15, 2021 1:16 pm
I have, what looks like, a NOS Motor Meter that is to be installed on the dash next to the switch. It has the heat tube and light wire. The face is like the one illustrated. If you or anyone is interested, email me.
Darel
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Fri Oct 15, 2021 5:02 pm
Dan & Ed have the right idea if you can do that. if not the lower tube will give you correct info for the water coming out of the radiator. If you know the differance you can calculate the temp in the engine. If you are waiting for steam to tell you have overheated the engine then the # to AAA will come in handy.
Craig.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri Oct 15, 2021 5:06 pm
I drilled & tapped the rear freeze plug (or whatever folks call them) for 1/2 in. pipe on my Racer for a mechanical gauge works great !
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Oct 15, 2021 6:46 pm
Your greatest heat of true engine temp is here. The dead engineer in the picture said so!
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Sat Oct 16, 2021 12:59 am
Steve is that the Rajo engine? Not sure how the water circulates in a Rajo but in a stock T that would be only a 25% improvment in the inlet pipe sending unit. Hank that does not look like the smartest engineer on the prodject. I don't think this is helping Al.
Craig.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sat Oct 16, 2021 10:52 am
Yes it is Craig - I'm running a rather stout water circulator to assist in water movement through the head and I use "stick-on" Caterpillar heat indicators in different areas to double check.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Oct 16, 2021 10:55 am
If you have a good radiator, you don't need a temperature gauge or a water pump. Why waste your time?
Ed Fuller
First Name: Ed
Last Name: Fuller
MTFCA Number: 29582
MTFCI Number: 22818
Post by Ed Fuller » Sat Oct 16, 2021 12:41 pm
My speedster body was on another chassis before I bought it. It had holes in the dash for three gauges. I installed the water temp gauge to fill one of the holes.
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Mon Oct 18, 2021 11:21 am
Went on a tour yesterday, some of the rout was on a highway with a 65MPH speed limit so the tour speed was between 35 & 45 MPH with a Temp. of close to 100* by the end of the tour. The first thing I noticed was my motometer no longer works. Engine never got up to 200* by the gauge it was nice to know under those conditions. Steve would like to know more about the Caterpiller stick-ons They would maybe solve the the discusion. And help with these issues. Have a friend with a T-Go head and had to put a circulation assist on it.
Craig.
