Any trick to getting this off?
Posted: Sun Oct 17, 2021 3:01 pm
by Mopar_man
So I'm trying to fit some wood in place and I see that I have to take off the big nut and top Iron support stud.
This is the nut.
Is there a way to hold this stud without having to use vice grips? I don't want to chew it all up.
Re: Any trick to getting this off?
Posted: Sun Oct 17, 2021 3:08 pm
by Scott_Conger
Double nut it, perhaps with thin jam nuts, and that will act as a head on a bolt and things can be taken apart
Posted: Sun Oct 17, 2021 3:09 pm
by Charlie B in N.J.
Remove the cap then do a double nut on the threads. Give you something to hang on to.
Posted: Sun Oct 17, 2021 3:27 pm
by Mopar_man
OK now I feel dumb. Thanks!!!!!!
Posted: Sun Oct 17, 2021 3:31 pm
by Mark Gregush
If it was painted in place, suggest scoring the pant around where it meets the body so does not pull or chip the surrounding paint.
Posted: Sun Oct 17, 2021 5:54 pm
by Scott_Conger
or simply saw a clearance slot into the back and slid it over/past the nut. No one will see it and it will still function fine as a tack strip
Posted: Sun Oct 17, 2021 7:13 pm
by Mopar_man
Well that worked. I used two nuts and it came right out. Then I showed my daughter that mechanical trickery.
Posted: Sun Oct 17, 2021 8:49 pm
by JTT3
It’s amazing all the trickerization you can learn here. Ha
Posted: Sun Oct 17, 2021 8:53 pm
by Mopar_man
I've been passing on all your tricks to my 16 year old.
