Generator cutout
Posted: Sun Oct 24, 2021 10:56 am
by Rod Petrie
Does anyone repair cutouts?
Re: Generator cutout
Posted: Sun Oct 24, 2021 11:33 am
by Oldav8tor
I think the one on the left is a John Regan voltage regulator. You might contact him (he's on this forum) and ask. I don't know about the other.
Posted: Sun Oct 24, 2021 2:23 pm
by Art M
The one on the left can be normally repaired by cleaning the points,and adjust so that the points close at about 6.5 to 7 volts. I clean and check mine once a year.
It is simpler to use a diode, but they can fail and burn up the generator armature like what happened to me when I tried a diode
Art Mirtes
Posted: Sun Oct 24, 2021 3:02 pm
by MichaelPawelek
Here is a cutout with diode inside. Note that a diode is not a voltage regulator.
Posted: Sun Oct 24, 2021 5:47 pm
by Ron Patterson
Art
The correct operate voltage for the reverse current cutout is 7.2 volts which is the charging voltge for a 6 Volt battey.
Ron Patterson
Posted: Sun Oct 24, 2021 7:29 pm
by Art M
Ron,
Thanks or the info. Four years ago I guessed at the voltage. I used 4 d cell batteries at the time and it worked. I now have a very good laboratory grade dc power supply.
Art Mirtes 3
