side curtains 1927 runabout pickup
Topic author - Posts: 84
- First Name: Bert
- Last Name: van Amstel
- * REQUIRED* Type and Year of Model Ts owned: Runabout pickup 1927
Does somebody have pictures and details from side curtains for a 1927 runabout pickup.
Bert van Amstel
Bert van Amstel
Nice movie of this Model T: https://youtu.be/jD1QJBZasdY
- MTFCA Number: 4838
- MTFCI Number: 115
Re: side curtains 1927 runabout pickup
- MTFCA Number: 121
- MTFCI Number: 16310
Pickup and roadster are the same. I'm wondering about Dan's photo above. I didn't know they put a flap on the RH side. Is this something the owner did?
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
Curtain opens with door, do not know how you could reach the door handle without a flap.
- MTFCI Number: 115
Larry is correct the original curtains on the runabout/runabout pickup only have signaling flap or toll paying flap on driver's side!
Passenger side didn't have one, the new curtains are from the old Carter's Cut and Cover Shop, and he put them on both sides, good for use anyway.
The attached pdf file contains sketch/ with dimensions, of the curtains for the '26-'27 runabout made from original pieces. See the note that no flap on passenger side. And see photo of original curtain on passenger side, no flap, but as the curtains fit loose at the door , and there are no snaps on the lower edge of the curtain, easy to lift the lower curtain edge and grasp the door latch!
- Last Name: Humble
Nice picture Dan, that clears it up.
- Last Name: Nunn
- MTFCA Number: 50321
The shape of the window in the rear panel as shown in drawing matches the shape seen in this 1935 photo. The lead photo is different.
- MTFCA Number: 121
The small window (light) as Ford called it on the front side curtains is the same size as that on the rear curtain on a '25. I assume that is the case on a 1926 as well?
- Attachments
- 12-27-09%20Holiday%20Tour%20002[1].jpg (63.59 KiB) Viewed 6039 times
- MTFCA Number: 121
I failed to mention, I made these side curtains, as well as the top from the original Ford drawings.
- First Name: Bert
I bought side curtains from Lang
Looks very good and fit also very good Can someone tell me how the origional connection is of the backpart of the side curtain
I have this on my T
The clips are round and aprox. 11mm in diameter
The rear side curtaine should be between
Bert
I have this on my T
Bert
- MTFCA Number: 121
I'm glad the pictures of original side curtains were posted. As you can see, they are different from Carters. Also Ford did not use lift the dot fasteners.
They used Anzo fasteners, which are getting difficult to find these days.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
- MTFCA Number: 2406
- MTFCI Number: 22213
Even though this NOS side curtain is labeled for 1925, I think that it is actually for 1926-27 roadsters. The "sockets" that are installed inside the rear top bows on 1926-27 roadsters and tourings must have the extra lip to project through the grommets on the rear side curtains. ( I think Larry Smith identifies these as ANZO fasteners.) A similar "socket" without the lip is used on the body panel between the doors on 1926-27 tourings and also on the doors of most 1927 roadsters and tourings. If you use the socket without the lip on the inside of the rear top bow, the fasteners that are crimped onto the rear curtain will not snap into the socket when the side curtains are installed. That lip is to allow for the thickness of the grommets in the side curtains when it is "sandwiched" between the top bow and the rear curtain where it wraps around the back and fastens to the top bow. I think this type fastener is only used on the 1926-27 Model T's, but maybe it was used on Model A's, too. I don't know. See the photos of the sockets an how the grommet fits snug on that lip. The grommets have to be installed quite accurately in the side curtains to match the sockets.
1922 Coupe , 1926 Touring
- First Name: Bert
Thanks, now I know mine are origional, but who can deliver me this round holes Parts? The rings
Lang?
Bert
Lang?
Bert
- First Name: Alan
- Last Name: Long
Don’t forget us Aussies and our friends in NZ and Canada with RHD!!! We need the RH opening
Alan
Alan
- MTFCA Number: 121
I've seen those mis-labeled 26 curtains before. Owning a 1925, I've received 26 curtains before, and have not been able to use them. 1925 & 26 owners, take note! Thanks for posting Jim!
