				Tire pump hose fitting - Found
				Posted: Tue Nov 09, 2021 8:50 am
				by Gator
				I have this pump that I just installed a rebuild kit in.  I am missing the fitting on the base to connect the hose to.  Does anyone know where to get one?
				Re: Tire pump hose fitting
				Posted: Tue Nov 09, 2021 10:17 am
				by R.V.Anderson
				What year is your pump, or what year car is your pump going with? There were several different styles. I have the drawings for all of them; they are simple enough that you could make your own.
				Posted: Tue Nov 09, 2021 10:19 am
				by R.V.Anderson
  I apologize; I misread your  post. I thought you were looking for the clamp that secures the hose to the fitting. Stupid.
				Posted: Tue Nov 09, 2021 12:47 pm
				by Dropacent
				I believe I have a loose original with the check valve.
Tmorsher@icloud.com and I’ll look
				Posted: Tue Nov 09, 2021 1:04 pm
				by Henry K. Lee
				I should have some too just need to know what thread size you require.
				Posted: Tue Nov 09, 2021 3:15 pm
				by Gator
				I got this pump to go with my '26 touring.  Probably not correct with the brass body but I like it.  I tried to determine the size.  First glance just figured 1/8" pipe, but way smaller than that.  1/4" fine slips in, 5/16" too big.  Got it in my mind that it might be the same size as a valve stem.  Acts like wants to start in but doesn't.  Threads may be dinged but I didn't want to go too far until I knew for sure.
				Posted: Tue Nov 09, 2021 5:48 pm
				by Henry K. Lee
				Will take a look tomorrow.
				Posted: Tue Nov 09, 2021 11:21 pm
				I have the same pump, or maybe an excellent reproduction, and it has no check valve. The chuck should have no center post, so the tube stem serves as a check valve.
				Re: Tire pump hose fitting - Found
				Posted: Wed Nov 10, 2021 10:09 am
				by Henry K. Lee
				Gator,
  I found a few in my odd box, closest one is a 5/16” x 24 NFT with a check valve. I do have one only of the odd 9/32” x 32 NFT with no check valve. $12.00 each plus shipping.
Let me know,
