Is this a TT truck bearing ??
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Thu Nov 25, 2021 11:07 pm
Going thru some more boxes from the auction. Found these two bearings. One is an original Ford bearing and the other is the modern replacement for it. The bearing is approx 4-1/2-inch OD, 2-3/8 ID, and 7/8 inch thick. I did not have a mic handy so I just measured it with a ruler. The picture shows the original part number with TT and Ford script. So is this a TT truck part, or for something more modern? Thanks in advance for any info
First Name: Adrian
Last Name: Whiteman
* REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Re: Is this a TT truck bearing ??
Post by A Whiteman » Fri Nov 26, 2021 12:18 am
As Adam notes below, it is the factory number of the inner bearing. It is not illustrated in the Ford parts book I have but is listed as part '1018'.
The dimensions are too small for inside diff bearings (approx 5" OD and 3" ID).
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Fri Nov 26, 2021 12:41 am
TT125 is indeed the factory number for the TT inner rear axle bearings.
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Fri Nov 26, 2021 7:54 am
What the modern bearing part number? Please share it with us.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
MTFCA Number: 50618
Post by Jeepbone1 » Fri Nov 26, 2021 8:02 pm
I’m pretty sure the new bearings are made by SKF. Part number is 212-2Z.
Brad
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Fri Nov 26, 2021 11:00 pm
I have been away from the shop a couple days. I'll try to remember to look at the part number tomorrow.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sat Nov 27, 2021 3:53 pm
The picture on the SKF box says "6212-" but I can't quite make out the something after the hyphen.
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Sat Nov 27, 2021 4:23 pm
Sorry to take so long to post the number.
It is SKF part number 6212/C3 on the bearing itself and on the box I can only read 6212-? The number or numbers are not readable
I looked in my TT parts pile and I do have a differental with the bearings still in place I'll try to check this bearing to the ones on the differential this afternoon.
MTFCA Number: 14383
Post by speedytinc » Sat Nov 27, 2021 6:23 pm
212 is the original side thrust rux bearing #. Current # 7212. 6212 would be the same dimensionally without side thrust.(never use in a rux)
As far a s TT, I know nothing. I would not guess them to use the same bearings. The alphabet behind the number indicates cage & seal info.
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Sat Nov 27, 2021 8:06 pm
I compared the bearing to one on a old TT diferental. The outside OD is the same. But the ID of the new bearing is larger than on the TT diferental. Does anyone have a center casting that the bearings fit on or an original bearing to measure the ID of the bearing or OD of the casting?
MTFCA Number: 14383
Post by speedytinc » Sun Nov 28, 2021 10:20 am
Its rux sized. 60x110x25mm
