New Warfords
Topic author - Posts: 392
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
New Warfords
Is there a New KC Warford transmission for TT trucks ??
Their website shows only one product being made. Will it work on cars and trucks both?
- MTFCA Number: 1219
Re: New Warfords
Like the original Warfords they were intended for truck use. Use in cars was secondary and probably occurs more today than back then.
- MTFCA Number: 51486
Re: New Warfords
One consideration when putting a Warford in a passenger T is driveshaft length. Shortening the driveshaft will make the U joint run at more of an angle and will cause the wheelbase to change more with load changes. A TT, having a longer driveshaft, would be less affected. Advantages of the Warford include lack of shift linkage and no increase in unsprung weight.
- Last Name: Pharis
Re: New Warfords
^^^^^ And overdrive...
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: New Warfords
Aluminum case Warford were for cars only! Under weight loads in the TT they would blow up. Cast iron were for TT but can be used in a car if the input shaft is shimmed or a auxiliary coupling is used. KC Warford’s can handle a TT as long as you do not haul 5 tons.
Hope this Helps,
Hank
Hope this Helps,
Hank
- First Name: Dennis
- Last Name: Prince
- MTFCA Number: 22802
Re: New Warfords
For awhile they advertised a truck and speedster version, you might try calling Layne Machine Works, their ad is in the Vintage Ford.
Re: New Warfords
I believe the truck and speedster versions were only of differing ratios to suit the application. The fitting is the same for all.
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: New Warfords
Are they two or three speed?
- MTFCA Number: 52564
Re: New Warfords
http://www.texastparts.com/mm5/merchant ... ory_Code=l
http://www.texastparts.com/mm5/manuals/WarfordTech.pdf
This chart shows red line, maybe could figure what red line would be for truck. Chances are you would never reach those RPMs anyway;
http://www.texastparts.com/mm5/manuals/ ... MChart.pdf
1920 Dodge touring
1920 Dodge touring
- * REQUIRED* Type and Year of Model Ts owned: 25 TT
Re: New Warfords
Give them a call. I have one in my TT but have not put a ton of miles on it. (pun intended) basically under, straight through and overdrive. Those guys are great. Racers too I think.
